Old 11-04-2022, 10:07 AM #1
ssyota4runner's Avatar
ssyota4runner ssyota4runner is offline
ssyota4runner is on a distinguished road
P2121 Throttle/Pedal Position Sensor. Pedal Commander (maybe)
I have a 2016 Limited with only 78,000 miles. Truck is limp mode, will not go above 60mph. Check engine light just came on with this code. I have had a Pedal Commander on my 4Runner for about 6 months. Does anyone think that the Pedal Command could have caused this issue?
Is this a easy or complicated repair?
Thanks
ssyota4runner is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 10:31 AM #2
Originally Posted by ssyota4runner View Post
I have a 2016 Limited with only 78,000 miles. Truck maybe in limp mode, will not go above 60mph. Check engine light just came on with this code. I have had a Pedal Commander on my 4Runner for about 6 months. Does anyone think that the Pedal Command could have caused this issue?
Thanks
Old 11-04-2022, 10:41 AM #3
hoppyjr hoppyjr is online now
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
Thanks
Hard to say, but my first step would be fl unplug the PC. Then scan for the code, read what it says. You can try clearing the code with PC unplugged and see if that fixes it.
hoppyjr is online now   Reply With QuoteReply With Quote
Old 11-04-2022, 10:51 AM #4
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Ive had this code come up multiple times during some rougher offroading and it will go into limp mode. I also run a pedal commander and keep my carista with me to clear the code.
The techs at PC asked me to disconnect all the plugs on the PC and check that they were clean. Then hook everything back up and make sure all the plugs are seated well with no play.
I ran through this process and haven't had the code come back up for a few years. BOL
El Dusty is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 09:38 PM #5
bbermann bbermann is offline
bbermann is on a distinguished road
Yes, uninstall the device, restart T4R, drive.
Reinstall device
bbermann is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 10:14 PM #6
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
I have a 2016 and the pedal commander for around 5 years. A couple notches above suck OEM response. No issue so far.
What are the settings on it? Mine are pretty moderate. I would try turning it down and reset the code to see if it reappears.
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 08:30 PM #7
That worked. Took the plugs apart and blew them out with compressed air.
Thanks
Old 11-07-2022, 08:31 PM #8
Set on one of the lowest. Took some cleaning and everything works now.
Thanks
Old 11-08-2022, 01:39 AM #9
itskml itskml is offline
itskml is on a distinguished road
I was doing research on deciding if I wanted to get a PC. Ran across some people saying "limp mode" may have been caused due to changing modes while having the food on the gas pedal
2021 TRD Pro
Xpel PFF Stealth | Blackvue XR750X-2CH | C4 Low Pro bumper | Come Up Seal Slim 9.5RS w/ Synthetic Line | Baja Design S8 20" | C4 Sliders | 4Runner Lifestyle smoked sequential turn signal | Rago Fabrication Molle Storage Panel and Shelf | Prinsu Full Roof Rack | Greenlane Ladder | Eibach TRD Pro Kit | Vivid Lumen FNG 5 Ditch Lights | Darche 180 Gen 2 Awning
itskml is offline   Reply With QuoteReply With Quote
command , commander , months , p2121 , pedal
Throttle Pedal Sensor Replacement natevans65 4th Gen T4Rs 17 10-22-2022 09:01 AM
P2121 code-pedal commander Lus06SR5 5th gen T4Rs 17 11-12-2020 09:21 PM
Pedal Commander JKRunner 5th gen T4Rs 10 05-21-2019 05:24 PM
Wiring diagram for gas pedal position sensor and brake pedal sensor? Seymore Butts 4th Gen T4Rs 0 05-23-2018 03:38 PM
Buying used - How to reset the throttle response/pedal position etc? characterzero 5th gen T4Rs 17 03-19-2012 07:33 PM
