Old 11-04-2022, 04:28 PM #1
scfw0x0f scfw0x0f is offline
scfw0x0f is on a distinguished road
Rock armor: different grades for different locations?
I'd like to do this build trying to keep the weight down a bit, so we don't wind up a 7,000 pound armadillo (great phrase @Easyrider18 !). I'm very much a measure 2/3/4/5 times, cut once type.
It seems like we could select different armor grades--thin/thick, steel/Al--for different locations based on likelihood of damage and the severity of cost/risk for damage. The difference between (for example) a full set of Bud Built skids in 3/16 steel with a diff skid, and 1/4 Al without the diff skid, is 97 pounds, which is 6% of the total cargo capacity of the 4Runner.
Has anyone done this or looked into it?
My thinking so far. This is really just to get the decision process started.
  • Rock sliders: very high priority, because the downside is very expensive repairs.
  • Front skid: low priority, because with a front-facing camera we should be able to avoid most damage.
  • Mid-skid: medium priority, proximity to oil pan.
  • Tranny/transfer case: low priority, they are pretty sturdy.
  • Fuel tank: high priority, catastrophic failure modes.
  • Rear differential: medium priority.
  • KDSS components: low/medium, not critical but expensive to fix.
  • ABS sensors: low/medium, same as KDSS.
  • Something else?
Comments? Once I get these priorities worked out, and I'm looking to all of you for advice on that, I can look at the specifics of protecting each location.
Thanks!
scfw0x0f is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 10:20 PM #2
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
It would be helpful if you provided information about the frequency of your off roading, type of terrain, and examples of trails you frequent.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 11:06 PM #3
spartacus's Avatar
spartacus's Avatar
35 inch tires would reduce the risk also.
Old 11-04-2022, 11:51 PM #4
Let's assume we're trying to construct a general model for a variety of tasks. While driving trails in Indiana (for example) may generally be lower risk than attempting high-risk technical trails in Utah or Colorado, is the risk profile for a specific location on a 4Runner substantially different relative to the risks to other systems? That is, for example, is the fuel tank always at the same level of relative risk vs. the rear diff, or are there operational modes that shift the relative risk among the various systems?
Old 11-04-2022, 11:58 PM #5
Jeremy556's Avatar
Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all
Jeremy556's Avatar
What kind of trails are you planning on doing?
I have bud's skids with some extra gusseting and modifications over the years to strengthen them.
To your list:
I would say the transfer case skid is probably highest priority - there isn't one stock, just a flimsy piece of sheet metal bolted to the transfer case and it is right at the break over angle where you are going to get high centered on rocks all the time. Bud's skids also add a frame cross member here, which is critical.
Rear diff is pretty low priority. Protection for the pinion and e-locker motor are nice, but the rear axle can take a good bit of abuse. Eventually it sucks when you can't remove the drain plug as the ring around it becomes one with the drain plug.
KDSS and ABS sensors don't need anything, they are well protected.
Rear LCA mounts are high priority, they will get chewed up in no time. Also, rear LCAs will bend when you drop on them.
Honestly, unless you are planning on doing 5+ rated rock trails, the stock 4runner protection is pretty good and better than most give it credit for, much better than some aftermarket skids.
Old 11-05-2022, 04:23 AM #6
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
WTF.... Are you trying to be dense for the sake of being dense?
Better idea: go take your vehicle offroading and find out what kind of offroading you like before you end up with a instagram build.
Old 11-05-2022, 10:05 AM #7
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Measure the height of the curbs at your local mall. Armor up accordingly.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 11-05-2022, 02:36 PM #8
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a name known to all comtn4x4 is a name known to all comtn4x4 is a name known to all comtn4x4 is a name known to all comtn4x4 is a name known to all comtn4x4 is a name known to all
comtn4x4's Avatar
Yeah break it then prevent it from getting broke again if possible.
IMHO the longer I wheel the rig the more I'm willing to risk. And honestly the more trail time you put in the greater the odds become of breaking something. You can't plan for everything.
'13 TE w/ KDSS, 4:56 Gears, Dobinson's IMS C59-352/C59-701V, Sonoran Steel KDSS Trac Bar, Overland Custom Design Control Arms. Fuel Revolver 17x9 +1 mm 5" Backspace, Falken Wildpeak A/t3w 285/75r17, Hefty Fabworks Aluminum Front Bumper and Full Skids, C4 Fab Dual Swingout Rear Bumper, OPOR Sliders, Northstar, Off-Grid Engineering, SPod, Blue Sea, Rigid, Baja Designs, KC HiLites, Stedi, Aplharex, National Luna, Drifta, Goose Gear, RAD Rubber Designs, Viair, Bandi Mount, URD, Gobi, ARB, Warn, Factor 55, Fourtreks, Axia Alloys, Desert Does It, Agency 6
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 08:55 PM #9
Shock Surplus Shock Surplus is offline
Shock Surplus is on a distinguished road
  • Something else?
Thanks!
Like others have said, really depends on the level of offroading one plans to do. If people plan to rock crawl at all steel over aluminum is a must. My 2 cents
Rock sliders: One of my first purchases, sliders are a must.
Front skid: Stock skids provide good enough protection for most, mine took a few hard hits if you are gonna touch any skid in the front its gonna be those
Mid-skid: Most people don't need it unless you are crawling, turtling and dragging ass
Tranny/transfer case: Most people don't need it unless you are crawling, turtling and dragging ass
Fuel tank: Mine have taken a few good hits, most won't need an upgrade unless you are in a very technical trail
KDSS components: Sliders and stock KDSS module skid plate will suffice for most people
Shock Surplus is offline   Reply With QuoteReply With Quote
Old 11-08-2022, 12:24 AM #10
Uhhh…. It matters because if you’re trying to save weight, stock armor is more adequate in many situations too. Lots of trails people consider off roading or overlanding are nothing more than overgrown fire roads that don’t really need armor at all. Context matters.
Old 11-08-2022, 01:13 AM #11
Sempre Nissart Sempre Nissart is offline
Sempre Nissart is on a distinguished road
What about shock skids or LCA skids?
Sempre Nissart is offline   Reply With QuoteReply With Quote
Old 11-08-2022, 04:20 AM #12
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
Front skid was my top priority. Ground clearance is not good and compound that with the hump in the middle of the dirt trail and the hump often has firmly planted rocks. Bud Built has done me well.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 11-08-2022, 08:22 AM #13
Finslayer83 Finslayer83 is offline
Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough
Front skid is a must
Finslayer83 is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 04:25 AM #14
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
It very much depends on your use. Different terrain will damage different stuff. For example Moab slick rock is going to be mostly big round rocks and ledges. So sliders, bumpers, and belly (transfer case). California rocks are more loose rock that will go into more places, so you really need the transmission, fuel tank, rear control arms, and rear frame mounts.
I don't think the rear diff needs a skid at all in most cases, nor does the front lower control arms. And the KDSS skids are solid. No reason to change them.
If you want to optimize for weight, Toyota did a really good job with the OEM steel front skid. It's thin and light but can take shit ton of abuse without failing. It'll look terrible after a weekend in the rocks. But it'll hold. The aluminum TRD pro skid looks strong, but is pretty weak. If you want to take abuse repeatedly over the years, then the heavy steel is what you need. It's the only thing that will handle constant rocks.
So you gotta pick what you want to do with it and go from there.
armor , damage , medium , priority , skid
any big differences between 00-02 limited grades 4x4Runner09 3rd gen T4Rs 14 01-23-2022 06:32 PM
KDSS armor must have for any rock crawling SilverTEP 5th gen T4Rs 1 09-15-2018 08:49 AM
best up grades for a 1st gen 4runner nashville67 Classic T4Rs 15 04-11-2017 09:12 PM
Steep Grades VolFF 4th Gen T4Rs 7 07-28-2007 11:14 PM
