Old 11-08-2022, 07:00 PM #1
proimion proimion is offline
Real Name: Carl
proimion is on a distinguished road
Real Name: Carl
Map lights not working
Looking for ideas as a fix for this seems expensive. My map lights on the overhead console stopped working, both when the door opens or by the push-up switch. I replaced the bulbs with no luck. It's not the fuse--and the weird little "shifter light" in the middle still works. All other interior lights work fine.
I pulled the overhead console and removed the bulb socket assembly and checked for voltage. It's a strange socket connector--removes with a quarter turn and then the voltage is delivered by two thin strips on a circuit board. I couldn't get any reading there (maybe I was doing it wrong?).
Anyway, it seems the only part I can replace is the entire overhead console assembly (minus the off-road dials), which is over $900! Here is the part: 2014-2019 Toyota 4Runner Overhead Console 81260-35651-B0 | Toyota Parts Center
2016 TE with KDSS, BFG KO2 in 265/70/17, Bilstein 5100 on all four corners with front set 1.75, Cornfed 1" rear spacers, RCI sliders, Dasaita 10" Apple CarPlay head unit, power folding mirrors, Alpharex LUXX LED projector headlights.
proimion is offline   Reply With QuoteReply With Quote
Old 11-08-2022, 07:06 PM #2
emmantik emmantik is offline
emmantik is a jewel in the rough emmantik is a jewel in the rough emmantik is a jewel in the rough
Did you replace the bulbs with LED's?
Are the bulbs burnt out?
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 11-08-2022, 10:16 PM #3
fkheath fkheath is offline
fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light
On some 4Runners, like mine, the lens on the light is also an individual on/off switch for that side. Be sure to press the lens to turn it on.
fkheath is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 01:32 PM #4
Real Name: Carl
Real Name: Carl
yep--using the switch as designed.
Old 11-09-2022, 01:34 PM #5
Real Name: Carl
Real Name: Carl
Yep--replaced with new LEDs just like the ones that were there. I had switched all interior lights to LEDs years ago and no problems for 5+ years.
console , lights , overhead , socket , voltage
Dashboard and Control Panel Lights not working (but tail lights are working) pmw42069 3rd gen T4Rs 6 05-06-2021 10:11 PM
Which fuse is for the back-up lights? (lights not working) nalbertasr5 3rd gen T4Rs 2 02-07-2018 03:30 PM
Brake lights and dash lights not working, just hooked up new trailer plug MichaelAngelo 3rd gen T4Rs 3 02-15-2015 11:30 AM
dome lights, and center lights not working yotawolfe Classic T4Rs 2 01-30-2015 05:53 AM
Fog lights not working Woodsie8 3rd gen T4Rs 4 02-08-2012 01:42 PM
