11-09-2022, 12:19 AM
34x10.50r17 Toyo AT3
First thread here and wanted to share. I debated back and forth for months before deciding and didn't find much info on these.
Toyo lists them as D load at 55lbs. Measure 33.5x10.6 running small like the BFG version.
Best part, and my initial interest they are sub 300 to 315 unlike the BFGs over 450 a tire.
I debated back and forth on 255/80, 275/70, and 285/70.
Searching here and elsewhere couldn't find much on them so went for them. I got them 298/ea from simpletire and shipped to a local installer.
For reference, I do have TRD Pro shocks with Eibach springs for the Pro and a 1/4 top plate spacer. Put me right at 22.25" in the front up from about 20 before. Back is right about 24 with slight rake.
I also installed JBA arms and Pro wheels. I removed my mudflaps in the front in advance and did the fender liner mod as well.
Post balance and alignment (3 degrees+) I have no rub. It clears the body mount by about 1/2" and the tires clear the arms by about 1"
Gave the height and width I was looking for. I plan to put a 255/80 as the spare underneath to use as spare only
Here are a few pics. Also have a YouTube link discussing as well.
I like them so far. Obviously are more of a 33 than a 34 but drives fine with stock gears. Can feel it off the line some but not really once moving.
22 Toyota 4Runner ORP Army Green
IndyGarage Amateur Hour Channel
5th Gen 1/2" Bodylift
5th Gen Raptor Light Adapter Plug
Use code IndyGarage10 for 10% Off
11-09-2022, 01:27 AM
looks fantastic
11-09-2022, 12:53 PM
awesome, thanks for the info.
were toyo's online measurements of 33.6 tall and 10.6 wide precise?
11-09-2022, 02:00 PM
Did you need to run and wheel spacers?
2021 TRD Off Road, 1991 Wrangler on F150 axles, 37s, 5.13 gears.
11-10-2022, 01:10 AM
Out of curiosity, what made you choose these over 255/80? Those were going to be my next pair (AT3 as well).
11-11-2022, 08:51 AM
according to Toyo site, the 34 is taller and wider. i bet the D rating rides a bit softer then the E.
Seems like an ideal size without having to run an e rated 255/80
11-11-2022, 01:41 PM
Makes sense, I just can't justify a tire size that I can't run in the spare well unfortunately.
11-11-2022, 05:08 PM
I think it'll fit. My 285/75/17s would fit. They're 34.0. although I actually used a 285/70/17 as the spare, but either one would fit in there.
11-11-2022, 05:20 PM
That looks like a really great tire size option. It was kind of the tire I always thought would be about perfect. I ran 285/75/17s and they were very similar in size. Just heavier and a bit taller and wider. But overall I really liked the size.
It's nice that there's so many options in this size range now. Not long ago there was almost nothing between the 33 and 35 sizes.
11-11-2022, 07:43 PM
throw a 285/70-17 in there. thats whats in our spot now. its close enough to work
11-15-2022, 03:06 AM
Unmounted yes, pretty spot on. Mounted and with a load, more closer to 32.5-33
By far run small! Width on the pro 7” wheels is right around 10.5 though
11-15-2022, 03:09 AM
Yep, that was the 3 main reasons. Slightly tall (not sure it actually is though in reality), wider, and D load
The final was that I haven’t seen anyone else local with them. Just wanted something different I suppose
11-15-2022, 03:13 AM
Somewhere, referring to the BFG 34x10.50, someone said it would fit. I think it would but even if it did, am going to look at getting a 255/80
It’s very close to the same height, but a little bit more narrow so it should give a little more ground clearance underneath… I guess only by about 1/2 at best. I don’t plan to rotate it the mix either just use it only as a spare
11-15-2022, 12:17 PM
BFGs are notorious for running small so even though they say 34" I guarantee they are a "large" 33".
