Old 11-09-2022, 12:19 AM #1
4Brewz's Avatar
4Brewz 4Brewz is offline
4Brewz is on a distinguished road
4Brewz's Avatar
34x10.50r17 Toyo AT3
First thread here and wanted to share. I debated back and forth for months before deciding and didn't find much info on these.
Toyo lists them as D load at 55lbs. Measure 33.5x10.6 running small like the BFG version.
Best part, and my initial interest they are sub 300 to 315 unlike the BFGs over 450 a tire.
I debated back and forth on 255/80, 275/70, and 285/70.
Searching here and elsewhere couldn't find much on them so went for them. I got them 298/ea from simpletire and shipped to a local installer.
For reference, I do have TRD Pro shocks with Eibach springs for the Pro and a 1/4 top plate spacer. Put me right at 22.25" in the front up from about 20 before. Back is right about 24 with slight rake.
I also installed JBA arms and Pro wheels. I removed my mudflaps in the front in advance and did the fender liner mod as well.
Post balance and alignment (3 degrees+) I have no rub. It clears the body mount by about 1/2" and the tires clear the arms by about 1"
Gave the height and width I was looking for. I plan to put a 255/80 as the spare underneath to use as spare only
Here are a few pics. Also have a YouTube link discussing as well.
I like them so far. Obviously are more of a 33 than a 34 but drives fine with stock gears. Can feel it off the line some but not really once moving.
34x10.50r17 Toyo AT3-0cf1822c-e04e-4837-90d8-77aaec24ba2d-jpg  34x10.50r17 Toyo AT3-7b0e02f0-54d0-4f89-beea-9062c68481f8-jpeg  34x10.50r17 Toyo AT3-155f0b67-d807-492a-aefe-780c16e1a85a-jpeg
22 Toyota 4Runner ORP Army Green
IndyGarage Amateur Hour Channel
5th Gen 1/2" Bodylift
5th Gen Raptor Light Adapter Plug
Use code IndyGarage10 for 10% Off
4Brewz is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 01:27 AM #2
looks fantastic
Old 11-09-2022, 12:53 PM #3
rheosibal rheosibal is offline
rheosibal is on a distinguished road
awesome, thanks for the info.
were toyo's online measurements of 33.6 tall and 10.6 wide precise?
rheosibal is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 02:00 PM #4
JLtoTRD JLtoTRD is offline
JLtoTRD has a little shameless behaviour in the past
Did you need to run and wheel spacers?
2021 TRD Off Road, 1991 Wrangler on F150 axles, 37s, 5.13 gears.
JLtoTRD is offline   Reply With QuoteReply With Quote
Old 11-10-2022, 01:10 AM #5
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
Out of curiosity, what made you choose these over 255/80? Those were going to be my next pair (AT3 as well).
91foxbody is offline   Reply With QuoteReply With Quote
Old 11-11-2022, 08:51 AM #6
according to Toyo site, the 34 is taller and wider. i bet the D rating rides a bit softer then the E.
Seems like an ideal size without having to run an e rated 255/80
Old 11-11-2022, 01:41 PM #7
Makes sense, I just can't justify a tire size that I can't run in the spare well unfortunately.
Old 11-11-2022, 05:08 PM #8
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I think it'll fit. My 285/75/17s would fit. They're 34.0. although I actually used a 285/70/17 as the spare, but either one would fit in there.
Old 11-11-2022, 05:20 PM #9
Jetboy's Avatar
Jetboy's Avatar
That looks like a really great tire size option. It was kind of the tire I always thought would be about perfect. I ran 285/75/17s and they were very similar in size. Just heavier and a bit taller and wider. But overall I really liked the size.
It's nice that there's so many options in this size range now. Not long ago there was almost nothing between the 33 and 35 sizes.
Old 11-11-2022, 07:43 PM #10
throw a 285/70-17 in there. thats whats in our spot now. its close enough to work
Old 11-15-2022, 03:06 AM #11
4Brewz's Avatar
4Brewz's Avatar
Unmounted yes, pretty spot on. Mounted and with a load, more closer to 32.5-33
By far run small! Width on the pro 7” wheels is right around 10.5 though
Old 11-15-2022, 03:09 AM #12
4Brewz's Avatar
4Brewz's Avatar
Yep, that was the 3 main reasons. Slightly tall (not sure it actually is though in reality), wider, and D load
The final was that I haven’t seen anyone else local with them. Just wanted something different I suppose
Old 11-15-2022, 03:13 AM #13
4Brewz's Avatar
4Brewz's Avatar
Somewhere, referring to the BFG 34x10.50, someone said it would fit. I think it would but even if it did, am going to look at getting a 255/80
It’s very close to the same height, but a little bit more narrow so it should give a little more ground clearance underneath… I guess only by about 1/2 at best. I don’t plan to rotate it the mix either just use it only as a spare
Old 11-15-2022, 06:11 AM #14
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Love that size of tire for these and it's what I plan on getting next. Looks great!
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 11-15-2022, 12:17 PM #15
BFGs are notorious for running small so even though they say 34" I guarantee they are a "large" 33".
arms , back , pro , spare , toyo
Anybody running 34x10.50 BFG KO2's here?? wmflyfisher 4th Gen T4Rs 19 01-06-2020 11:06 AM
Set of 4 35x12.50r17 BFG KO2s Ventura CA mwray8909 For Sale: Suspension/Wheels/Tires 1 02-21-2019 05:52 PM
FS... BFG KO2 34X10.5X17 SET OF 5 $750 SoCal ProjectV8Runner For Sale: Suspension/Wheels/Tires 5 05-01-2018 11:25 AM
34x10.5 BFG AT KO2, anyone run them? Keith_PDX 5th gen T4Rs 39 03-07-2018 01:00 PM
BFG KO2 34x10.5x17 Wheel Fitment Texas777 5th gen T4Rs 5 09-18-2015 01:48 PM
