Old 11-11-2022, 04:44 PM #1
fvlewg65 fvlewg65 is offline
fvlewg65 is on a distinguished road
Battery light illuminated on the dash
I’m trying to help a lady from work with her 2015 4Runner Limited. I’ve read through multiple posts and I still can’t figure it out.
Last February her battery died and was replaced, everything was running fine and then in June the Battery light on the dash came on. She had her ex-father-in-law look at it and he’s said the alternator is charging the battery and not to worry about it.
She asked my opinion so I said I’d have a look. This is what I’ve done:
OBDii code reader - no significant codes, check engine light wasn’t even on
Tested the battery - seems fine, 12.78 at rest, drops slightly under load then recovers. Rated at 930 CA, battery analyzer said 873 CA. Battery connections are nice and clean, no corrosion.
Tested the alternator - charging fine but removed it and took it to a starter and alternator repair shop, they said it checked out on their test equipment but said maybe there was something internal that they couldn’t detect with the voltage regulator. So I replaced it with a brand new one. Inspected the wiring from the alternator.
Tested the charging system - 10.85 cranking volts, 14.21 alt idle volts, 14.13 alt load volts
Checked the #22, 7.5 amp fuse in engine bay
Checked the ground wires.
Battery light is still illuminated on the dash.
I am flummoxed! I have no idea what to check/next or what the problem is. I’d hate tell her to go to the dealership because I can’t figure it out. Any advise would be greatly appreciated. Thanks in advance.
fvlewg65 is offline   Reply With QuoteReply With Quote
Old 11-12-2022, 10:44 AM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Since all of your voltages tests appear to be normal, and the tests by the shops have show that everything is working correctly, it is understandable that you are perplexed. I would be too..
Perhaps your best approach would be to get a good understanding of the charging circuitry in the 4Runner. The "battery" light in cars is really turned on by the voltage regulator circuitry and has nothing to do with the battery it's self. Perhaps looking trough the diagnostic steps in the 4Runner repair manual would help: TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
fkheath is offline   Reply With QuoteReply With Quote
alternator , battery , charging , fine , light
Battery Light + Whine + Low Idle + New Battery TT4RLtdV8 4th Gen T4Rs 23 06-17-2022 09:51 PM
4th Gen No Codes No Start & Battery Light On, It's not the battery! V8Man 4th Gen T4Rs 18 10-05-2019 10:35 PM
Please help - Engine shut off + Battery light, A/T Fluid light and OIL light Lamer 3rd gen T4Rs 11 09-03-2018 06:04 PM
Ditch light switch always illuminated BikeDestroyer 3rd gen T4Rs 16 12-18-2017 09:16 PM
Battery light on dash Japsfinest 5th gen T4Rs 4 11-17-2011 07:15 PM
