11-12-2022, 03:44 PM
2016 suddenly when turning in 4 high, binds up
my 4runner,, which i had just driven the last couple days,, has low easy mile 40k miles,,,,i was turning around in my cul de sac on pavement to load onto trialer,, it was in 4-high,, all of sudden i feel resistent as i am turning,, and then as i was turning left, the 4runner like raised on the left and lowered in the right,, like i was driving over a bump on the front left,, but i wasn't. any thoughts? i took it over to some dirt and it didn't do it in 4 high or low, but once back on the pavement, same thing in 4-high. as i drive straight, it works fine. i would be a little concenred at higher speeds in 4-high.
2016 4runner trail KDSS, 3" icon lift w/ uca's, Icon rims, Falkens E rated, 10k smitty winch, heftyfab alum front bumper, heftyfab sliders, frontrunner roof rack, ARQ awning, LED lights everywhere, home made magnetic paint protectors, bunch of recovery gear i never use, a mentally disabled driver, big stupid tires and a million gallon gas tank cause it's a 4runner
11-12-2022, 03:56 PM
You need an AWD Limited
11-12-2022, 04:09 PM
That’s normal. Don’t make sharp turns on pavement when in 4WD.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
11-12-2022, 04:57 PM
You have a Part-Time 4wd, with no differentiation front to rear in the transfer case. Both T-case outputs turn at the same speed. When you turn, each tire follows a different path, which means each tire is rolling on the ground at a different speed.
With open diffs in the rear axle and front differential housing, they can compensate for the different tire speed at opposing sides left-to-right. But with the front and rear tires following different paths through the turn, the front and rear driveshafts would need to spin at different speeds, too. But with the Part-Time 4wd T-case having no way to allow a different speed between the front and rear outputs, you get binding in the driveline, which is what you felt when you turned while your Part-Time 4wd was engaged.
That binding can create extra wear, and even break parts in extreme circumstances.
That's why it's advised that you only use Part-Time 4wd in slippery conditions, so that binding can be relieved by tire spin.
As mentioned, the Limited models have Full-Time 4wd, which incorporates a differential in the T-case, which allows front and rear driveshafts to turn at different speeds, eliminating binding.
11-12-2022, 05:46 PM
This is why used vehicles scare me.
11-12-2022, 08:05 PM
Real Name: Ted A Hamilton
Originally Posted by forgetful
this is why used vehicles scare me.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
11-12-2022, 09:26 PM
lmaoooo. this should be a good thread.
all those mods in the signature, doesnt know how 4x4 works......
11-12-2022, 10:16 PM
Can I ask, why are you even driving in 4-High? Was it snowing? Or even raining?
…of course, unless sarcasm… I hope
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
11-12-2022, 10:51 PM
Lol, I thought the same thing. Then I noticed “a mentally disabled driver” in his signature and all was clear.
11-13-2022, 01:34 AM
He could've been trolling. Or he truly didn't know the answer. Everyone who now understands how a Part-Time 4wd works, at one point didn't know.
What's the phrase: "The only stupid question, is the one not asked".
It's been attributed to several people throughout history, but I doubt we'll ever truly know the source.
