Old 11-18-2022, 02:34 AM #16
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
I think your driveline angles are off. I would read up here and go from there: Driveline Geometry 101 – Tom Wood's Custom Drive Shafts
Since you mentioned you extended the driveshaft, I have also seen on some builds where the driveshaft was extended too far and the slip yoke was bottoming out on acceleration, giving a feeling like axle wrap. I would double check this. With that much lift, it may come down to needing a double cardan (CV type) shaft.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 11-18-2022, 03:47 AM #17
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
What you have is probably not axle wrap. You likely have very bad anti squat from bad suspension geometry. New links won't help. You need a full new suspension setup.
4-Link Suspension Guide | Anti -Squat, Anti-Dirve, and Roll Center Basics
The rear suspension just isn't compatible with that much lift. The links are way too short. Especially the upper rear links. by that I mean you need to relocate the fame mounting points a lot further from the axle so the links are longer and the angles of them are less extreme.
axle , bad , changed , rear , suggestions
Rear Axle Seal: Suggestions? nissanh 3rd gen T4Rs 22 12-17-2019 11:49 PM
Axel wrap! 2014 Warthog Classic T4Rs 6 03-24-2019 03:05 PM
axle wrap help klipsch Classic T4Rs 8 10-18-2014 01:24 AM
Axle Wrap thegray1 Off Topic 3 02-05-2014 11:08 AM
Rear axle replacement + diff locking questions, NEW 4RUNNER suggestions! Rama 3rd gen T4Rs 0 05-02-2011 09:20 PM
