Old 11-15-2022, 12:08 AM #1
kags1969's Avatar
kags1969 kags1969 is offline
Real Name: Chris
kags1969 is on a distinguished road
kags1969's Avatar
Real Name: Chris
belt cut hole in Drivers side AC line, going to try and replace myself, some ??
I have a 2016 4runner with a Magnuson. The SC Belt chewed a hole in my drivers side AC line after about 500 miles. I will zip tie it out of the way after I replace it.
I got a qoute for a local shop, it was around $800 to replace the line ~200 parts and $600 labor, so I thought I would give it a try.
I have the guages and compressor coming, and have watched a few youtube videos. My big question is how do I make sure that I have enought oil in the AC system without taking the compressor off.
There is oily residue on the skid plate at the bottom of the engine bay, so I am sure I need to add some, just dont want to over/under fill.
Anyone have good advice or approach to the problem?
kags1969 is offline   Reply With QuoteReply With Quote
Old 11-15-2022, 12:45 AM #2
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Do you have a vacuum to evacuate the system? I thought that was part of the procedure when replacing any part of the A/C system.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 11-15-2022, 12:53 AM #3
Jeremy556's Avatar
Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all
Jeremy556's Avatar
Your oil level will be fine, don't mess with it.
Replace the line, then use standard gauges and a vacuum pump to draw vacuum on the system for a while, then turn off and wait to see if any leaks. If not, recharge and you should be good to go.
Old 11-15-2022, 02:08 AM #4
Whippersnapper02's Avatar
Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold
Depending on how long it’s been open to atmosphere, I’d get a new dryer.
Old 11-15-2022, 04:11 AM #5
seatia seatia is offline
seatia will become famous soon enough
You cannot, only way is to drain and flush system and then fill to spec.
Usually all hoses and tubes hold 1oz and the accumulator holds 1oz
It is advisable as mentioned to replace the accumulator when a system is opened up.
Replacing accumulator and the hose personally I would replace with 1.25oz of oil
Be sure to pump down to 500 microns to rid the system of any moisture.
seatia is offline   Reply With QuoteReply With Quote
Old 11-16-2022, 09:35 PM #6
kags1969's Avatar
Real Name: Chris
kags1969's Avatar
Real Name: Chris
I do have a vaccume pump.
belt , compressor , drivers , line , replace
Aftermarket Bumper put a hole in my AC line gimlithepirate 4th Gen T4Rs 11 07-12-2022 01:42 PM
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
WTB: 3rd Gen 4Runner Seat Belt Assembly, Drivers Side (Oak Color Ideally) nobb Want to Buy/Trade 8 12-05-2013 01:12 PM
WTB: 03 Drivers side seat belt retractor Presta24 Want to Buy/Trade 0 02-06-2011 08:37 AM
WTB Fuse Box and Drivers Side Seat Belt Genesis98 Classifieds - buy & sell (no commercial ads please) 1 02-04-2008 07:52 AM
