12-30-2022, 01:27 PM
Real Name: Russ
Real Name: Russ
285s on SR5 wheels? Possible?
Hey folks,
As the title suggests, I am trying to see if I can put 285s on my stock SR5 wheels. I have tried searching and cannot find the magical combo that has the info I am looking for. While getting new wheels may be simpler, from a cost perspective, I am waiting a bit longer for those. My current tires wore uneven so am now in the market and looking to go up in size. Any insight would be great. TIA
12-30-2022, 03:49 PM
Real Name: Howard J. Turkstra
Originally Posted by Ykket
Hey folks,
Most 285 tires say minimum 7.5” wide rim, but there are many people here who have put them on 7” wide rims without issues.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
12-30-2022, 07:48 PM
Real Name: Russ
Real Name: Russ
Thanks. I am starting to get some of that feedback as well. While I may not have any issues, there would be that slight worry that something could happen when I air down, etc. The problem is that new wheels can be quite expensive when added all together with tires. First world problems haha.
12-30-2022, 10:25 PM
Airing down isn't your issue. The skinnier rims will retain the beads better. Treadwear is your issue and it's a minimal one.
Plus the sidewalls will protect the skinny wheels even better.
12-31-2022, 05:47 PM
Hey folks,
Try looking here: Modifications, Write-Ups, Quick Links, and FAQ's
Then look here: Changing Tire Size or Wheels? Read this first! - Toyota 4Runner Forum - Largest 4Runner Forum
Plenty information.............
Best Regards,
Saker
01-01-2023, 01:49 AM
Yes they will fit. I ran 285s on stock width wheels for years with no issues. Airing down to 15 psi and the tread wear was no different than on my 9" wide wheels now.
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
01-02-2023, 04:54 PM
What kind of premature wear did you see? It would help diagnose if the tire size, pressure, or suspension issue. I just put 285's on my SR5 stock wheels a few days ago, they work fine.
2017 4runner SR5 4x4
01-03-2023, 02:25 PM
The 7" wide rim with a 285 is a non-issue. You will be fine. May rub a little in places, but that's it.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
01-04-2023, 12:23 AM
The TRD PRO wheels are only 7in wide also. My TRD OFF ROAD came with PRO wheels and I run 285-70 -17 KO2s with no problems. Most tire manufacturers "recommend" at least 7.5 in wheels for 285s but a few say 7inches are fine. The tire shop that intalled my tires said 285 were fine on my 7in wheels, but wouldn't install any wider tires than that. I have heard of people putting 295s on 7 in wheels, but I haven't seen it myself. The standard TRD OFF ROAD wheels are 7.5 inches and could accommodate wider tires.
2020 TRD ORP with KDSS. 285/70 17 BFG KO2s. Bilstein 5100s w/ stock springs on top perch in front, and Bilstein lift springs in rear. SPC UCAs. RCI rock sliders. C4 Fab Low Profile front bumper with Smittybilt H20 12k winch. Factor 55 Flatlink E. RCI roof rack, Baja Designs and cheap Amazon led lights, Switchpro 9100, BeyondWraps hood scoop stamp.
01-04-2023, 06:48 PM
Are you able to get 285s on an SR5 without a lift? I am looking to upsize, but don't want to lift just yet.
01-05-2023, 09:59 AM
Yes, but plan to trim the bumper a bit and probably do the fender liner mod.
