Old 06-16-2020, 11:42 PM #1
17Jetta 17Jetta is offline
17Jetta is on a distinguished road
Xreas failure at 30k miles
Title pretty much says it all. My drivers front shock is leaking at 30k miles. 2016 Limited purchased as a leftover March of 2017 so barely out of 36 month bumper to bumper.
Already spoke with Toyota Corporate and they were not very helpful. Toyota is offering $400 as a goodwill gesture towards replacing drivers front shock, lines, accumulator, and passenger rear shock. Dealer estimated $2200 at first, but once Toyota came to the rescue, dealer is now at $1800 for the job. So $1400 out of my pocket for an obviously defective part from the factory.
As of now, I (we) haven’t noticed any degradation in handling. However, this is my wife’s daily driver and she does most of the parental duty hauling around our two amazing children.
I purchased the 4Runner because I thought it was the best mid size SUV available and had Toyota reliability behind it. I was wrong. Toyota has really let me down.
This has been beat to death on the forums and I should have known better. Xreas is failure prone.
Looking for recommendations on what to replace the Xreas suspension with. We get dirt on the tires 3 or 4 times a year, so just looking to replace with OEM quality. Not looking for a lift. Would prefer a compliant ride to off road capability.
Appreciate any input or commiserations.
17Jetta is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 11:42 PM #2
Old 06-17-2020, 12:12 AM #3
4Rums 4Rums is offline
4Rums will become famous soon enough
I feel your pain and frustration. Mine went out at 60k. The main thing I noticed when it went bad was extra body roll. I almost soiled my pants when I took a highway exit curve a little bit faster than usual and experienced much more body roll. You can replace the Xreas with any conventional suspension for a lot less. Bilstein 5100 are a popular choice. You can check for TRD Pro take off etc. Good luck.
4Rums is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 12:35 AM #4
Thanks for the response and advice.
Yes, if I wasn’t clear in my original post, I have zero intentions of putting any Xreas suspension back in the truck.
I intend to strip all xreas components and replace. Would like to keep a compliant sporty (little to no body roll) ride that the limited comes with though. Not sure if that’s possible. Have heard the Bilstein 5100’s can be a little stiffer than stock.
Also looking for longevity. Maybe I’m crazy but I think shocks should last a minimum of 75k miles with zero issues.
Old 06-17-2020, 08:15 AM #5
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
5100s are a good inexpensive option. You could also consider 6112s up front and 5160s, 5100s, or fox 2.0s in the rear in conjunction with a new spring set depending on whether or not you want any lift
tm965 is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 09:34 AM #6
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
5th Gen:
5th Gen Limited X-REAS Leak - Options?
2010 Ltd - X-REAS - Replacement Questions
5th gen and XREAS system
Also common on 4th Gen:
Best Replacement Shocks when removing the XREAS? - Toyota 4Runner Forum - Largest 4Runner Forum
Replacing XREAS with regular shocks - Toyota 4Runner Forum - Largest 4Runner Forum
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 10:55 AM #7
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I'd pull it and install your own suspension.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 11:35 AM #8
TRDPRORUNNER's Avatar
TRDPRORUNNER TRDPRORUNNER is offline
TRDPRORUNNER is on a distinguished road
Same here. Failed at approx. 50k
TRDPRORUNNER is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 12:26 PM #9
That’s the plan.
Looking for input on options. Not really interested in a lift, just want something that handles as good or better than stock and is reliable.
Old 06-17-2020, 12:38 PM #10
flatspin flatspin is offline
flatspin is on a distinguished road
Mine failed at 60k. I knew it probably would so was expecting it. I haven't replaced it yet (Icon Stage 2 looking at me from their boxes as I type), but the only thing I've noticed is wheel hop until they warm up. Basically like the tire is out of balance, but it goes away after a few miles.
2014 Grey Limited 4Runner 4x4
Installed: XenonDepot HID (Philips 4300k) LB & LED Pro HB, Weathertech mats, Shrockworks Sliders, SCS Stealth 6 Wheel, 275/70/17 BFG KO2 Tires, Daystar 2.5/1.5 lift, Demello 1 hoop Aluminum front bumper, and full OEM tank skid.
flatspin is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 12:54 PM #11
Real Name: Sparky
Real Name: Sparky
That’s the plan.
If you don't want a lift Bilstein shocks and some Eibach coils are a good choice.
Since the cost is similar, you might as well get one that can be adjusted to get some lift out of it.
Old and (c)rusty.
Old 06-17-2020, 12:56 PM #12
phillyd2's Avatar
phillyd2 phillyd2 is offline
Real Name: Dave
phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough
phillyd2's Avatar
Real Name: Dave
No brainer. Take the cash, rip them out and replace with at least Bilsteins.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
phillyd2 is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 01:06 PM #13
Cash is only in play if spent at the dealership, so that's a no go unless I order something through the parts department maybe.
Old 06-17-2020, 01:32 PM #14
That’s the plan.
While I didn't do the work there, I was quoted 6 hrs of labor to do the job at the dealer (conventional shocks front/rear + front coils), so if you have the capability to do it yourself, go for it.
Old 06-17-2020, 01:49 PM #15
phillyd2's Avatar
Real Name: Dave
phillyd2's Avatar
Real Name: Dave
Ah. Then let them keep the cash and do the rest.
dealer , failure , shock , toyota , xreas
Gates water pump failure after 3,000 miles asdfman7 4th Gen T4Rs 9 04-22-2015 02:03 PM
06 sport brake failure! 9200 miles.. dirtjunkie Problems & Warranty Issues 13 10-16-2011 08:28 PM
Mileage on XREAS before failure or lift? Casper421 4th Gen T4Rs 10 06-21-2011 12:55 AM
xreas suspension bad at 22k miles? ptung07 4th Gen T4Rs 12 12-14-2006 12:45 AM
Possible Xreas Shock Failure - What are my options? HuntRunner 4th Gen T4Rs 11 12-06-2005 03:50 PM
