Old 11-26-2022, 06:36 AM #1
IH784 IH784 is offline
IH784 is on a distinguished road
Stripped skid plate bolt
Good morning,
I’ve got a 2015 SR5 with a stripped skid plate bolt. Am I able to mod this to accept the TRD skid plate? Everything I’m reading is saying it used M10 bolts but, I’m pretty sure the bolt I jacked up is an M8.
IH784 is offline   Reply With QuoteReply With Quote
Old 11-26-2022, 11:56 AM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
The dealership stripped both of my 2 front skid plate bolts. I didn't realize this until long after the warranty had run out. You can pay someone to tap the threads again or just get a bigger, harder bolt and force it in there. That's what I did and many years later it's holding just fine.
Edit: Maybe I misunderstood. You mean the bolt itself or the threaded area in the frame is stripped? If it's just the bolt you can go to Lowes or Home Depot and match it up using their bolt identifier. It's a simple device you just screw your old bolt into.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 11-26-2022, 01:00 PM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by IH784 View Post
Good morning,
There is a really good thread on this forum that tells how to replace the bolts with studs (TRD Skid Plate Mounted w/ Studs 2010-2021)
Once you get the old bolts out, you might consider doing this so you don't have future problems.
fkheath is offline   Reply With QuoteReply With Quote
Old 11-26-2022, 01:04 PM #4
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
Dealership stripped two of mine too. Idiots like to use impacts where you don't need that much power.
You could chase the threads and clean them up if it's not too bad, or you could go with a helicoil. I'd much rather a helicoil over putting an oversize bolt.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 11-26-2022, 01:30 PM #5
I ended up tapping them out and replacing all four bolts. I’ve got smaller bolts m8 instead of the m10 used in the thread that shows how to mod the skid plate for studs. Are those larger holes there as well? Do I just install the studs and then the other kind of skid plate?
Old 11-26-2022, 05:32 PM #6
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Well, 19 years down the road and I'm good :-) I don't take it off road so I just keep the skid plate there because, well, it's there. It pulls my bass boat and Airstream just fine, which is why I got it. It hasn't been back to that dealership except for tires. I have an independent that's Toyota certified for all the things I can't fix.
Rich
Kentucky
Old 11-26-2022, 10:30 PM #7
Helicoils are inferior. You should use a Timesert: ++ TIME-SERT Official Threaded inserts for stripped threads, blown out sparkplugs,
Old 11-26-2022, 10:44 PM #8
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by fkheath View Post
for what he is using it for, it doesnt' really matter. i think they will all work well in that application.
I have used helicoils in the past with great success on high stress/load (i.e. swing arm latch) and its still holding up strong. The only reason i choose it was it easily available at the neighborhood o-reillys when i desperately needed it.
Old 11-28-2022, 12:56 AM #9
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Just FYI - the support bars that the skid plate bolts to are themselves just bolted on. So if you can't or don't want to fix the threads you can just replace the support bars. Not the cheapest option but it will reset everything back to how it was new.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 11:07 AM #10
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
I just did helicoil in one damaged one. Switched to 1/2 head with 5/16 thread. OEM is M8 1.25 with variable lengths depending if its front rear or the longer center ones.
Grug556 is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 02:42 PM #11
orcking orcking is offline
orcking is on a distinguished road
Good morning,
DO not torque bolts more than 12-15 NM
I am actually surprised that these can strip easily in the frame, as the frame is steel and not aluminum...
and do not take it to dealer.. LOL
orcking is offline   Reply With QuoteReply With Quote
bolt , i’m , plate , skid , stripped
What to do when you have stripped skid plate bolts. 2012sr5 5th gen T4Rs 54 03-07-2022 07:02 AM
skid plate holes stripped, advice??? HIMILESV8SPORT 4th Gen T4Rs 15 01-21-2021 08:31 AM
Stripped bolts on skid plate anonymousgromers 4th Gen T4Rs 17 09-03-2020 11:09 PM
Stripped skid plate nut willo 5th gen T4Rs 6 12-30-2018 07:11 PM
