Old 12-07-2022, 10:18 PM #1
sunnah sunnah is offline
sunnah is on a distinguished road
Question License Plate Lights not working
Hello, I did an interior light swap in my 2017 4Runner with the VLEDs. I could not get the map light bulbs out so I replaced the license plate bulbs instead. But they would not work. I tried all options. I put the stock ones back in and they do not work either. I am at a loss now and cannot figure out what went wrong. Could it be connected to the interior bulb swap? Please advise. Thanks.
sunnah is offline   Reply With QuoteReply With Quote
Old 12-08-2022, 06:13 AM #2
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Silly question maybe, are you "sure" the lic plate bulbs worked before you tried to swap?
Do all lights on the interior work now?
Check lic plate bulb with a known good bulb, if that's a no go, check fuses.
Best Regards,
Saker
Old 12-08-2022, 10:40 AM #3
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
Did you try rotating it 180* like you would flip a USB plug upside down? Unlike incandescent bulbs, most LED bulbs have polarity and need to be installed a certain direction.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 12-08-2022, 10:41 AM #4
Bobby12many's Avatar
Bobby12many Bobby12many is offline
Bobby12many will become famous soon enough
The license plate bulb socket is not symmetrical and the bulbs will only function when inserted a specific direction... seems unlikely that you happened to install each of the bulbs backwards, but its worth noting.
If that isnt the issue, I would definitely check fuses as a next step
Bobby12many is offline   Reply With QuoteReply With Quote
Old 12-08-2022, 01:31 PM #5
MasterFoo MasterFoo is offline
MasterFoo will become famous soon enough
Did you turn the stalk to on position?
MasterFoo is offline   Reply With QuoteReply With Quote
Old 12-08-2022, 07:07 PM #6
djeepin djeepin is offline
djeepin is on a distinguished road
Why would someone want to have license plate light brighter ?
djeepin is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 12:49 AM #7
The cooler color temp looks more modern. You can always choose a bulb with lower output.
bulbs , license , plate , swap , work
LED License Plate Lights Marfy 4th Gen T4Rs 19 08-01-2019 08:16 PM
License plate lights first gen 1974RUNNER Classic T4Rs 0 10-26-2015 06:02 PM
Tail Lights, Markers, License Plate, Dash Lights all out! aeroneer1 3rd gen T4Rs 3 09-01-2012 06:53 PM
removing 2004 tail lights and license plate lights YOLO 4th Gen T4Rs 2 09-25-2009 09:38 AM
