Old 11-30-2022, 11:58 PM #1
Dianna's Avatar
Dianna Dianna is offline
Dianna is on a distinguished road
Dianna's Avatar
Have KDSS? Check this out!
I have a 2014 Trail Premium. I live in NE Ohio where they use salt brine and it's extremely corrosive but I wash my truck religiously in the winter and I use a couple of gallons of WoolWax on the undercarriage before the snow flies. I read a post here about someone having a leak near the KDSS module because it was packed with mud so I had planned on pulling the module cover and checking mine when I was prepping to apply the WoolWax. I am horrified at what I found! I'm going to POR15 the lines and coat everything down with WoolWax and check it every few months from now on. I wish I could give credit to whomever posted about the rust issue under the module cover, but I read that a while back and am not kicking myself for not checking mine sooner. I assume this is galvanic corrosion caused from two dissimilar metals. Someone feel free to correct me if I'm wrong. The module is made of aluminum and the cover is steel, but I think the void being filled with dirt/salt allowed the metals to be "in contact." Anyway, I urge y'all to take that cover off, it's just 2 12mm bolts under the drivers door and keep that area free of mud, salt, the remnants of the animal that darted under your wheel... should be part of your regular maintenance!
Have KDSS? Check this out!-317736802_10218269598771937_8387370955718018070_n-jpg  Have KDSS? Check this out!-317824399_10218269599531956_3676522252110063594_n-jpg  Have KDSS? Check this out!-317894806_10218269599011943_7539470378714063407_n-jpg
2014 Trail Premium with KDSS
2006 Tacoma
2001 4Runner Sport
1977 FJ40
Dianna is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 12:57 AM #2
JoeBand's Avatar
JoeBand JoeBand is offline
JoeBand is on a distinguished road
JoeBand's Avatar
Damn! I hope that cleans up well for you.
I can second that taking the cover off should be easy to keep an eye on it. when i removed mine to put on my sliders, it took just a minute.
best of luck.
2016 Silver TEP "Zilla"
JoeBand is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 01:24 AM #3
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
There is such a thing as galvanic corrosion, but that's dissimilar metals in contact with each other. You can see where they were in contact isn't too bad.
This is just salt left to sit in the area for extended periods of time.
02SE is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 05:58 AM #4
Matt831 Matt831 is offline
Matt831 will become famous soon enough
That is one of the worst I have seen posted.
I make it a habit to take off the cover twice per year and wool wax the unit when doing the rest of the truck.
I believe Wool Wax also recommends to not do any undercarriage high pressure cleaning in the winter when their product is applied.
Hopefully you get that cleaned up and protected before there is a problem. I imagine that there are many trucks out there in similar conditions with owners that have no idea.
Matt831 is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 11:35 AM #5
Dianna's Avatar
Dianna's Avatar
I haven't had an issue with the WoolWax washing off with a high pressure undercarriage wash. One of the reasons why I prefer it over Fluid Film.
2006 Tacoma
2001 4Runner Sport
1977 FJ40
Old 12-01-2022, 12:03 PM #6
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
In the Land Cruiser world we cover the valve and body with marine grease.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 03:10 PM #7
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
I've pulled the cover off my KDSS module a number of times and it looks nothing like that. But I also don't live in the rust belt.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 05:20 PM #8
bluebullet's Avatar
bluebullet bluebullet is offline
Real Name: Blue Bullet
bluebullet is on a distinguished road
bluebullet's Avatar
That happened to me on my 2011 Trail. They suggested I apply dielectric grease to the contacts. Repair estimate was $3K for a $1.7K option. I traded it in for a 2020 ORP and just purchased the 10 yr (3 +7) warranty for $1,360 ($0 deductible) before the 3 year warranty expired. Next time it will be on Toyota.
Pretty hard to fight the mag. chloride here in NW Montana. Drives the truckers crazy.
Happy Trails
2020 ORP w/ kdss, 1999 SR5 5sp, 2017 Chev Duramax (Shimmy), KTMs and ATVs for offroad
As a lady recently said "If you can't fix it with a hammer, you have an electrical problem."
bluebullet is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 06:08 PM #9
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Those lines are toast. Such a bad design.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 10:48 PM #10
Dianna's Avatar
Dianna's Avatar
Shush, lol. POR15 is saving those lines!!! Fingers crossed...
2006 Tacoma
2001 4Runner Sport
1977 FJ40
Old 12-01-2022, 11:26 PM #11
Dianna's Avatar
Dianna's Avatar
I thought for a sec about trading this in for a new one until I just looked up current MSRP, and nothing available near me. Everything is "in transit." So many other things I'd rather spend 25k on that isn't any different (other than this KDSS mess) than what I have!
2006 Tacoma
2001 4Runner Sport
1977 FJ40
Old 12-02-2022, 12:09 PM #12
baldrik78's Avatar
baldrik78's Avatar
If it was me, and my KDSS system looked like that, I'd ditch the system entirely and get a local fabricator to install an antirock in the rear and call it a day.
Old 12-02-2022, 01:55 PM #13
Ripper238's Avatar
Ripper238's Avatar
Well that certainly doesn't look great, impressed no issues with it looking like that though. Ill make sure I check mine now and then.
My question is what the hell is WoolWax??? Is it from sheep's wool? lol
Old 12-02-2022, 02:47 PM #14
Jivewalker's Avatar
Jivewalker's Avatar
Lanolin based corrosion protector. FluidFilm is a popular brand name, I spray the underside of my LC with it annually. It smells for a while but does a great job and is easily washed off if needed.
I am fragile.
Not like a flower.
But like a bomb.
Old 12-02-2022, 03:52 PM #15
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
Let’s see the after pics
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
cover , free , module , read , woolwax
5th Gen. KDSS vs. Non-KDSS handling performance & sway bar diameter differences. CS223 5th gen T4Rs 60 12-08-2021 06:48 PM
RCI Skid Plates KDSS vs Non-KDSS - What's the difference? jthoms1 5th gen T4Rs 13 09-09-2018 10:24 AM
Are the alignment specs the same for KDSS and non-KDSS models? transistor 5th gen T4Rs 4 05-18-2018 07:28 PM
New 4R Purchase: KDSS vs Non-KDSS with Modified Suspension and Added Weight? yellowdog 5th gen T4Rs 5 12-13-2017 01:32 PM
Alert: Riverside CA Dealer refused to check KDSS on lifted Trail bluebaron 5th gen T4Rs 38 09-26-2012 07:45 PM
