Old 12-07-2022, 01:23 PM #1
Matto2786 Matto2786 is offline
Matto2786 is on a distinguished road
18 T4R Limited Vibration
Want to see if anyone else has had this issue. I have been trying to find the answer to this for months. I have a Limited with approx 76k miles on it, which I bought in Sept of 2021. Shortly after purchase, I noticed a subtle vibration in the floorboard, gas pedal, and center of the steering wheel only when accelerating. When I coast at any speed, it goes away completely. The harder I accelerate, the more pronounced the vibration becomes, but it is not audible. The best way to describe it is like a phone vibrating in your pocket. Some days, the vibration is more noticeable than others. I’ve had the transmission drained and filled twice in the last year. I have had the fluids in the diffs and transfer case changed. I have had the driveshaft lubricated. Engine and cabin air filters are clean. I just had the spark plugs changed, and had the fuel injection system cleaned. I’ve had the tires balanced 4-5 times and two alignments done since July. Vibrations usually start around 2k rpm. When I rev the engine in neutral or park, I notice the vibrations, but not until closer to 3k rpm. Three different shops in the last year say that they can’t find anything wrong. A buddy of mine says that it just might be the extra components of the AWD system that I’m feeling, but I feel if that was the case, there would be dozens of threads on this. Again, the vibration is subtle and I’m sure a lot of people would just live with it, but I’m convinced there is something off that is causing this. Any help would be appreciated.
Matto2786 is offline   Reply With QuoteReply With Quote
Old 12-07-2022, 01:52 PM #2
MasterFoo MasterFoo is offline
MasterFoo will become famous soon enough
I have same year and model as your truck. Same story, alignments from several shops, road force balance from three shops, rotate tires several times, replace lower control arm bushings. You can see the list goes on, I still havent found a solution. Maybe it is the Full-Time 4WD system...
I did have a torque steer problem, that was fixed with a good alignment. Matching caster helped tremendously.
Next on my list are probably, replace lower control arms or front passenger axle, this is the side where I feel most my vibrations.
MasterFoo is offline   Reply With QuoteReply With Quote
i’m , i’ve , rpm , subtle , vibration
08 Limited 4WD V8 Steering Wheel Vibration lemii 4th Gen T4Rs 3 04-19-2022 01:53 PM
2014 Limited Vibration nelson4568 5th gen T4Rs 3 01-22-2015 06:46 PM
1999 4 runner 2wd limited vibration TOYO4RUNN Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-17-2013 11:54 AM
Noise/Vibration 2011 Limited Edition kl67 5th gen T4Rs 7 03-09-2011 05:16 PM
08 V6 Limited 4wd noise & vibration KB084RUNNER 4th Gen T4Rs 2 11-14-2010 11:49 AM
