Old 12-07-2022, 04:41 PM #1
IFD933 IFD933 is offline
IFD933 is on a distinguished road
2014 T4R Hard steering - replace lower coupling shaft?
In the fall of 2021, the steering in my 2014 T4R stiffened up, not real bad, but you could definitely feel the extra effort needed. From comments on the forum, seemed like the lower u-joint on steering column.
I sprayed the u-joint a few times with Aero-Kroil and the steering loosened up, probably back to normal or close to it. That got me through the winter of 2021-2022 and with the warmer weather in the spring and summer this year, haven't had any issues.
I guess as expected, with colder fall temps, steering has stiffened up again. I figure it's time for the real fix. Thought I'd run this by the forum, but it looks like this requires replacement of the lower coupling shaft which includes the lower u-joint. It looks like Toyota P/N 45203-60181 with a best price of about $185.
I assume it is possible that if you pulled the shaft and got a P/N on the u-joint itself, you could replace just the u-joint. However, it looks as though removing the shaft can be rough and it might get damaged so just going with the entire lower coupling shaft is the way to go.
Just wanted to run this by the forum for anyone else that has gone through the repair to see if I'm missing anything? I'm probably going to buy the coupling shaft from Toyota and have my local shop do the work. Cold garage and no lift, I think I'll pass on doing this repair.
IFD933 is offline   Reply With QuoteReply With Quote
coupling , lower , shaft , steering , u-joint
Lower steering shaft bad? COhailtr4 4th Gen T4Rs 6 05-09-2022 11:43 AM
2014 T4R - Hard steering IFD933 5th gen T4Rs 10 12-19-2021 05:24 AM
Aftermarket lower steering shaft? dave4242 4th Gen T4Rs 8 07-02-2021 10:29 AM
Power Steering Gear Box Input Shaft Leak: Replace Seal?? nobb 3rd gen T4Rs 21 09-22-2017 03:28 PM
98 4Runner, Needs new Steering coupling, anyone have measurements, for a universal ? TheFriZ 3rd gen T4Rs 1 10-14-2014 11:11 AM
