Old 12-14-2022, 09:06 AM #16
John in NC John in NC is offline
Real Name: John
John in NC will become famous soon enough John in NC will become famous soon enough
Real Name: John
I’m “that guy”. I paid for the transmission service at the dealership.
Lots of reasons as stated.
Another is when you go to sell the car at 200,000 miles and there are two or three transmission fluid exchange services on your Carfax, it gives the next buyer some peace of mind + resale value.
John in NC is offline   Reply With QuoteReply With Quote
Old 12-14-2022, 02:02 PM #17
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough
Tar Heels are smart, even if a transplant��. I’m a Tar Heel born, a Tar Heel breed and when I die a Tar Heel dead��. Salisbury native
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Salvo Jimmy is offline   Reply With QuoteReply With Quote
Old 12-14-2022, 09:04 PM #18
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
The question I have is has anyone taken a new vehicle and measured the "3 quarts" removed for the drain and fill? It seems when I did mine I drained more than three quarts...
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 12-15-2022, 12:55 AM #19
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I got 1-1/2 from the check plug and 2 more from the drain plug.
Transmission Fluid Change procedure
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 09:54 AM #20
dedonderosa dedonderosa is offline
dedonderosa will become famous soon enough
i did about 5 drain an fills.
drained it
filled it
ran if for a few mins
drained it
filled it
ran it for a few mins
etc
did this about 5 times until i started noticing the fluid coming out was coming cleaner and cleaner unit it looked almost like brand new fluid then let it get up to temp and did the level check procedure. i use about 12-15 qts doing it this way and im happy with the outcome
dedonderosa is offline   Reply With QuoteReply With Quote
Old 12-18-2022, 11:11 AM #21
dipNrip dipNrip is offline
dipNrip is on a distinguished road
Curious to what you paid? Debating on doing myself vs stealership doing it. They quoted me 385 locally which seems really high. Use to be just below $300.
dipNrip is offline   Reply With QuoteReply With Quote
Old 12-18-2022, 11:14 AM #22
drained it
filled it
drained it
filled it
etc
Makes sense. Even doing it via the cooling lines you’ll mix new and old and your way is way easier.
How long did you run the vehicle after filling? If you wait too long it’ll be too well mixed to get a lot of the old out. Not sure how long it should take to cycle the fluid out of the pan. This is where the cooling method is better as you pull out the old as goes through the line
Old 12-18-2022, 12:18 PM #23
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Seems to be an overwhelming fear of undoing a transmission cooling line going on here.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 12-20-2022, 08:47 AM #24
everytime i filled it back up with the amount that came out at each drain. i shifted through the gears a few times slowly. i would say overall i let it run for 2-3 minutes max. after doing it all those times id say it looked like brand new fluid coming out. then i overfilled it slightly and hooked up the scanner and let the trans get up to correct fluid check temp and did the fluid check procedure. done
Old 12-20-2022, 09:48 PM #25
hero1234 hero1234 is offline
hero1234 is on a distinguished road
Y’all sure do trust your dealer alot ha. Nothing wrong with having someone else do it. To say it’s complicated baffles me. I have zero mechanical experience and have so for changed every fluid in my 4Runner. Now it was a pain in the rear pumping the fluid back in the transmission but hardly complicated. I did spend the extra money to get a reader so I could read the temperature that way.
hero1234 is offline   Reply With QuoteReply With Quote
Old 12-24-2022, 03:42 PM #26
1000MPH's Avatar
1000MPH's Avatar
Make a sprayer pump for under $20.
Old 12-24-2022, 04:42 PM #27
I bought a little hand pump from auto zone that cost about 11 bucks. A little smaller than a grease gun. Worked like a champ.
000 , drain , fill , miles , qts
Should i drain and fill? nathanroyse 3rd gen T4Rs 29 08-22-2020 04:19 AM
Need help! Transmission Drain & Fill Samm25 4th Gen T4Rs 1 04-29-2019 11:05 AM
Coolant drain and fill. Block drain plugs. lj4r 4th Gen T4Rs 2 11-24-2018 07:11 PM
ATF Drain and Fill, 5th Gen leje0306 Maintenance/Detailing 0 10-02-2013 08:13 AM
Doh! '03 V6 4x4 drain and fill quadzillabill 4th Gen T4Rs 5 05-11-2008 07:24 AM
