Old 12-12-2022, 04:28 PM #1
t009166's Avatar
t009166 t009166 is offline
t009166 is on a distinguished road
t009166's Avatar
right turn signal issue: help please
Hi all, I am running into an issue and all previous steps to mitigate haven't worked. I have a 2014 4runner
Last week my right turn signal stopped working. If I go to turn right the dash will blink once and then stop. I hear the relay click once and intermittently see the front and rear turn signal flash once and then stop. If I hit the hazard button it also flashes once and then stops. My left turn signal is fine.
I have checked all fuses and replaced the flasher module as well as replacing the LED resistor in the right headlight. it is still not working. I have the alpharex aftermarket headlights and I ran a multimeter to see if there was signal. I get power to the light but it doesn't fluctuate when the turn signal is on like on the driver's side turn signal.
Has anyone else experienced this? i am at a loss and don't want to be raped by a mechanic trying to hunt down this electric gremlin.
TIA
t009166 is offline   Reply With QuoteReply With Quote
Old 12-13-2022, 08:05 AM #2
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Do your right-side front and rear parking lights operate normally? The only reason I ask is that one time we traced a totally weird similar situation down to a dual filament bulb where one filament had failed and laid down on the other one creating a short between the two different circuits. (Yes, a true one in a million shot.)
Another thing to try to eliminate a possible cause is to disconnect the front, then the rear parking / turn signal bulbs, then try the directional. If you have LED taillights, disconnect the turn / running portion. This will either zero in on a cause or rule several out.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 12-13-2022, 05:10 PM #3
t009166's Avatar
t009166's Avatar
The right rear light also does not flash but once when I indicate. This is why It doesn't seem to be a bulb issue as they both flash the one time before stopping.
Old 12-13-2022, 05:31 PM #4
Roger that. I'd still disconnect the front, then the rear turn signals to see what happens.
issue , signal , stop , turn , working
Passenger DRL turn signal issue GCEMSPETE 4th Gen T4Rs 1 10-11-2020 04:44 PM
Front Turn Signal Issue chadd925 4th Gen T4Rs 36 07-19-2020 06:04 PM
Recurrent turn signal issue, anyone else? S Brake 4th Gen T4Rs 10 11-12-2017 02:50 PM
Need help with turn signal issue kishanSR5 3rd gen T4Rs 15 11-11-2014 05:43 PM
Turn signal/elecrrical issue bmtimber 3rd gen T4Rs 2 01-03-2012 02:45 PM
