Old 12-12-2022, 04:14 PM #1
kadinh kadinh is offline
kadinh is on a distinguished road
Audio System Causing Short?
I’m pretty much out of ideas on how to fox my issue and want to see if any more experienced members have some thoughts…(lots of details to follow, hopefully providing enough detail to resolve the issue)
Everything has been going fine since installing my audio system a few years ago (previous thread of mine) except the occasional message that the Maestro unit was disconnected for a few seconds or the radio would restart (I think due to overheating occasionally). A while back my driver rear speaker wasn’ didn’t have any output, but that wasn’t a priority at the time.
A few months ago my wife went to turn on the car and there was nothing…no clicking, no engine turning…just dead. I have a portable jump starter and got it started right up. I thought it was strange since I have a new optima red top battery; after starting the car, the battery showed13.7V. Hadn’t happened since.
I went to the post office one morning, car started like it always does, I went inside the post office, came back out, unlocked the car with the fob, interior lights were on. I turned the key and……dead again. I got the jumper out and started the car, it started but died right after revving up. I waited a few seconds and it fully started up. I thought it was because it was colder outside but it happened again a few days later, exact same thing. Now it’s gotten to the point that I’m not sure if the car will start or not.
Here are some observations:
- amp is installed under front passenger seat
- everything works, even accessories, up until the point key is turned to ignition position
- car did this on Thursday last week, I was getting out to get the jumper and my wife opened the passenger front door and all the light came back on, car started w/o jumping.
- the next day, it died again. My wife was by herself and called her bro in law who is a mechanic. He advised her to check the amp under the seat. She couldn’t see it so she slid the seat back, lights came on, car started
- the next day, it died on me, same process as usual. Accessories work, lights on, car loses power, first jump car dies after turning over, second time runs normally.
- checked the fuses on the amp and some (not all) fuses under hood, none are blown. I didn’t check the other ones since they don’t seem to pertain to this issue.
- after car dies/starts, all radio settings are retained and not erased
- I have a URD MAF sensor calibrator installed as well
I haven’t been able to work on it since Saturday because I got the flu. Any suggestions or help would be greatly appreciated. I have attached pics with the amp connections and ground for amp. I can take more photos if it would help to troubleshoot. Thank you very much everyone!
Audio System Causing Short?-8e06f964-c5bf-4a1a-b73b-434e95e470ba-jpg  Audio System Causing Short?-0d370f21-1de7-4c48-8c13-ac29e66ce730-jpg  Audio System Causing Short?-b82e1f24-7db5-446f-b2b6-5ec61627be3f-jpg
kadinh is offline   Reply With QuoteReply With Quote
Old 12-12-2022, 05:39 PM #2
fkheath fkheath is offline
fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light
My thoughts are it may not have to do with your sound system.
13.7 volts with the engine running is a bit low. Should be 14 volts or a bit higher. Why is it low? Could be something is taking too much current and the alternator can't keep up, or the alternator could be dying.
What is the battery voltage when the car is off (and has been sitting for a few hours)? Should the a bit over 12 volts. If not, your new battery may be bad.
First step would be to find out why the charging voltage is low. Might disconnect the power to your sound system and see if the voltage returns to above 14 volts. Otherwise, have your alternator tested.
fkheath is offline   Reply With QuoteReply With Quote
Old 12-12-2022, 07:54 PM #3
Jeremy556's Avatar
Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all
Jeremy556's Avatar
I would start with load testing battery. Optimas are not what they used to be. Then eliminate your modifications (remove amp fuse and disconnect aftermarket radio) and see if the problem persists.
Old 12-12-2022, 07:56 PM #4
gakattack gakattack is offline
gakattack will become famous soon enough
I would get your alternator checked, along with your battery. I had something very similar happen with my Maxima (with an upgraded audio setup), but with an Optima Yellow top. Battery exhibited the same symptom as yours, once, then it was fine after I jumped it. At this time, I also upgraded the alternator.
On a side note, I *HIGHLY* recommend that you clean up the wiring around your power and speaker terminals. I'm seeing some loose wires around your power and pulled out speaker wires.
Look into getting wire ferrules (example from Amazon) and heat shrink tubing. Your wires should look something like this:
https://www.f150forum.com/attachment...s-photo696.jpg
for the smaller speaker terminals, look for a ferrule kit that includes the crimping tool.
2018 ORP, 2001 S4 Tial605, 2001 Maxima, 2013 GS350
gakattack is offline   Reply With QuoteReply With Quote
Old 12-12-2022, 10:34 PM #5
Thanks everyone for the suggestions. I will try them out and come back with what I find.
Old 12-14-2022, 03:05 PM #6
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about
flyrv9's Avatar
First one of those 2 big wires connected to the back of the unit looks like it's overheated and is discolored. Next I'd redo those grounds - clean off the rust and remove the coating on the metal buy burnishing or grinding it off so you have good ground contact. High resistance ground can cause overheating. Check your work with a meter. It should read almost a dead short (your ground connection to another known good bare metal ground point. Once you have that fixed, then coat ground connection to prevent rust or corrosion with some sealant - nail polish works.
Old 12-15-2022, 12:09 PM #7
97BlackAckCL's Avatar
Real Name: Chris
97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of
Real Name: Chris
Definitely go to Advanced Auto and have them load test your battery and alternator, like others mentioned, Optimas are not good quality at all anymore and I had nothing with problems with them after they moved their manufacturing to Mexico.
Second thing, that ground is ridiculous and unsafe, please redo the ground and find a proper way to mount to the chassis. I have my amp mounted under my passenger seat, and found a ground in the passenger side pillar where the seat belt is located, I used that ground and it's worked great for years.
2017 Nautical Blue SR5 Premium - Black Emblems, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, VR ECU Tune, RCI Skid Plate, Morimoto MLED 2.0 Headlight Retrofit, Morimoto LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Tinted Mirror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, CaliRaised Rock Sliders, BajaRack Full Length Roof Rack, Kenwood DMX1057XR, Infinity Kappa Door Speakers and 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, Blackvue DR900S Dash Cams
Old 12-16-2022, 07:01 PM #8
This is 100% correct. After my yellow top dies, I'm searching for something else to put in my car.
amp , back , car , lights , started
OEM Audio + 5th Gen 4Runner audio system headpaneer 5th gen T4Rs 630 06-07-2022 08:17 PM
FS: OEM Audio Plus System 500 rrdouleh For Sale: T4R Items 1 05-30-2021 03:14 PM
What system is best to replace 2014 Limited JBL premium audio system leatherlips 5th gen T4Rs 0 01-26-2020 07:45 PM
Help!! Random intermitent short causing problems 206pete Classic T4Rs 5 03-06-2015 02:13 PM
AU003-03 06/13/2003 Audio System - JBL System Static Noise CBR_GUY_IA TSB 0 07-12-2009 10:54 PM
