12-16-2022, 06:35 PM
#16
If you don't need the door lock cylinders on the front doors, an idea (from the old Jetta/Golf days) is to see if you can get a set of rear door handles to work on the front doors. Of course, the one on the tailgate is still exposed, but you'll have two less locks for them to mess with.
2018 ORP, 2001 S4 Tial605, 2001 Maxima, 2013 GS350
12-17-2022, 06:45 AM
#17
Real Name: Ted A Hamilton
Originally Posted by Too Stroked
I feel your pain, but remember this. If you "theft proof" one area of your vehicle, the average thief will just move on to the next way to get in - and possibly cause even more expensive damage. In your specific instance, you've already noted that the thieves apparently have no problem breaking glass to get in. (Personally, I'd prefer to have my glass broken as opposed to messing up my door locks though. Glass is easier to fix.)
On a related note, I used to work at a large marina where we winter stored a number of pretty large cruisers. We always instructed our customers to take everything valuable out for the winter and leave all the cabin doors open. Why? Because thieves trying to steal things will cause all sorts of more expensive damage busting through cabin doors.
As an old friend of mine in law enforcement once told me, "You can do whatever you want to theft proof something, and the best you can hope for is to deter the amateur thief. If a professional really wants what you have, they have the means to get it no matter what you do."
I hope that helps.
My Granpappy always said, a lock only keeps an honest thief out.😂lol
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
12-17-2022, 08:41 AM
#18
My friend with an NA Miata just leaves the doors unlocked and nothing in it. A lot less expensive then replacing the soft top every time someone cuts it open. Not a great solution… but it does work if you can manage not leaving anything of value inside.
12-17-2022, 12:11 PM
#19
These peel and stick plastic covers that go over the key portion could do the trick, certainly not fool proof and easily removed but might confuse thieves enough that they don't try to remove it and stick a screwdriver in. They are pretty cheap and you'd probably have to paint or wrap them to match your paint Exterior Door Handle Overlays For 4Runner (2010-2023) — 4Runner Lifestyle
2015 TEP - Magnetic Grey w/ KDSS
12-17-2022, 03:00 PM
#20
Here’s an idea.
12-18-2022, 08:51 AM
#21
Originally Posted by Salvo Jimmy
My Granpappy always said, a lock only keeps an honest thief out.  lol
12-18-2022, 10:05 AM
#22
simplest solution, leave the doors unlocked. or, buy a beater and drive it to the trailheads.
12-18-2022, 10:37 AM
#23
shoot the thieves. hiking sucks anyways, camp out by the car, bang bang.
2016 TE : Grocery Getter, 285/70R17 Cooper at3 XLT, Prinsu Rack, King Coilovers, DuroBumps, Wheelers T13 coils, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA, VIVID RACING Tune, URD Y pipe, RCI skids, Marlin Crawler gussets, DRKDSS sway bar controller
12-18-2022, 07:13 PM
#24
Real Name: BLACK TRD PRO
Put a dummy that looks like it’s taking a nap in the front seat. Hopefully they don’t rape the dummy. Angeles Forest has changed a lot since I first started driving there in ‘75. Taking the assault rifles and hiking all over the place. Designated shooting areas. Four wheeling on some great open trails all over. Skiing at Waterman and Baldy. Even fishing in the back streams north of Buckhorn It was a local paradise. Then in the late 80’s it started to change. Break ins, littering, shooting and hunting in illegal areas by illegals.
12-19-2022, 12:40 AM
#25
Real Name: Dave
Real Name: Dave
Originally Posted by 2021nightshade4x4
Range Rovers have a key hole but it’s covered by a solid cap so it appears you don’t have one.
On Toyotas, I wonder if you could keep the driver side cylinder but put a cap from the passenger side on it that you could pop off if you needed.
There's no door lock on the passenger side. Only one on the driver's side door.
The problem is when they destroy the lock you often don't see it until you try to use the key to open the door. Meanwhile the busted lock causes a drain on the battery which leaves you with a dead battery in very short time. it also ruined my battery by going dead and recharging often and may times over the course of the last year. I just paid $300 for a new Optima Yellow Top 35-750 battery.
See my original post.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
12-19-2022, 12:42 AM
#26
Real Name: Dave
Real Name: Dave
You need the door lock when you have to use the key to get in. Like when your battery is dead. I just want to cover it so it can't be tampered with.
12-19-2022, 12:47 AM
#27
Real Name: Dave
Real Name: Dave
This could work.
The driver's side overlay has a hole in it for the lock so it doesn't do the trick. I wonder if the right-side door would cover the left side door handle?
12-19-2022, 12:56 AM
#28
Real Name: Dave
Real Name: Dave
I've been camping and hiking in Angeles National Forest since the 1970s. I remember some of these freedoms. My fist car was a 36 hp VW bug that didn't lock and I never had a problem way back then.
Now there are break-ins every day. Illegal dumping of all kinds of hard to get rid of trash is filling the landscape. And police enforcement is non-existent. The LA County Sheriff is responsible for crime enforcement but I never see them on the highway.
I'm tempted to wait in the bushes with a gun and shoot the vandals when they appear. Only two problems with that. I don't own a gun and laying in weight to shoot someone is a very serious crime if you get caught.
12-19-2022, 03:45 AM
#29
It really is a shame how nice it use to be and that there isn’t any enforcement. But, without ethics, morals and especially consequences, it won’t get better.
12-20-2022, 03:42 PM
#30
Real Name: Dave
Real Name: Dave
Consequences
I think we're way beyond teaching ethics and morals to people. The world is going to hell when people steal because they can get away with it and when they shoot each other for no good reason. There's way too much violence in society today. But don't get me started...
Consequences will make a difference.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
