Old 12-16-2022, 08:54 AM #1
dedonderosa dedonderosa is offline
dedonderosa will become famous soon enough
Bought new wheels, need longer studs? rear studs on front?
Hey guys so i bought a set of Work S1HC from showstopper offroad. i was reading a lot of info about doing extended front wheel studs as there isnt a lot of bite on the lugs due to the stock short wheel studs. i tried looking into getting gorilla ET "extended thread" lug nuts but i dont think they are going to fit into my wheels. My question is how many of you are running the rear 4R studs on the front as i hear they are about 1/4in longer. Any input would be much appreciated. thanks guys
dedonderosa is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 10:26 AM #2
i read some guys run the rear studs on the front for that reason yep. it's been a while since I read that though. I believe in one of the wheel spacer threads its mentioned.
Old 12-16-2022, 01:21 PM #3
I got these from my local supplier to compare
Old 12-16-2022, 01:55 PM #4
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
I have been running longer front studs from a Toyota Matrix for 60,000+ miles with no issues. I got the idea from this forum on past modifications.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 04:18 PM #5
i sent you a message. but if you dont see it. you think there will be any issue running the matrix studs with oem wheels and lugs when i put my stock wheels back on for winter time length wise ?? im not running any spacers either
Old 12-16-2022, 05:32 PM #6
I can’t guarantee that using the longer studs would work with the OEM lug nuts. You’d be fine using the rear studs up front though. The matrix studs are a lot longer than the OEM front studs that come on the 4Runner. Like you, I’m running aftermarket wheels without the ability to use an ET lug nut.
Old 12-17-2022, 12:01 AM #7
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
I bought ARP studs for a Lexus from Summit Racing then cut them down to the exact length I needed. They are much stronger than OEM.
ARP Wheel Studs 100-7715
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
bought , extended , front , studs , wheel
spidertrax spacer studs, need longer ones orbot 3rd gen T4Rs 0 06-16-2022 11:10 PM
longer front wheel studs for spacers chipsahoy 3rd gen T4Rs 2 03-27-2020 09:01 PM
Anyone swap longer studs onto front of 4Runner? CodyX36 3rd gen T4Rs 14 04-26-2016 08:46 AM
longer studs alex56 4th Gen T4Rs 2 06-04-2011 08:52 AM
replacing 22re manifold studs w/ 7/16x14 studs Alow Classic T4Rs 0 12-17-2010 04:40 AM
