Old 12-16-2022, 11:26 AM #1
sunnah sunnah is offline
sunnah is on a distinguished road
Question Unwanted Condensation Inside the Cabin
2017 SR5 base 24K
I have noticed this in the past but I did not think anything of it until now. We are in the cold/winter months in Virginia but it has not snowed yet. I windshield has a lot of condensation on it and it is dripping down the windshield and a little bit of it is actually dropping on my dash. It may or may not be connected but I notice first a lot of fog so I ran my rear and form defogger on the highest setting and it did not work at all on the front and the rear got just a bit from the top. I do have tint on the rear window. So I thought perhaps my rear defogger lines were damaged and I need to replace the entire window. I also thought my HVAC motor was not working properly and need replacing. The condensation that formed about 4 days ago is still there and there are more streaks of water dropping down my windshield. Please advise. Thanks.
sunnah is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 12:00 PM #2
GG5thGen's Avatar
GG5thGen GG5thGen is offline
GG5thGen will become famous soon enough
GG5thGen's Avatar
It sounds like your HVAC system is not drying the inside air properly.
GG5thGen is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 12:24 PM #3
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
does the inside have a "sweet" odor...unlikely on a newish 4r, but the heater core could have a small leak. A sweet smell is the smell of coolant.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 06:28 PM #4
If that is the case how do I test and replace if required?
Old 12-16-2022, 06:28 PM #5
I do not smell anything sweet. Can I test?
Old 12-17-2022, 08:34 AM #6
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Make sure the AC is on, even if you are heating. It will provide dry air that will pick up the moisture.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 12-17-2022, 01:10 PM #7
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
Watch your overflow tank under the hood. If it doesn't change level, no coolant leak.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 12-17-2022, 03:23 PM #8
BimmerChop BimmerChop is offline
BimmerChop is on a distinguished road
First I would make sure you don't have any unwanted water leaking into the cabin... Something like clogged sunroof drains could lead to excess moisture. Or if you have ever swapped out the roof rails? I would look there.
Also, if you have ever knocked your shark fin antenna, I would look at that too. Doesn't take much... Even going through an automated car wash can damage the seal on those enough to let water through.
BimmerChop is offline   Reply With QuoteReply With Quote
Old 12-17-2022, 06:58 PM #9
ArthurKotb's Avatar
ArthurKotb ArthurKotb is online now
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
I agree with BimmerChop. It sounds to me like you have a water leak somewhere. Have you checked under the floor mats for wet areas? If you have a leak around your windshield or even the wiper motor shafts it could be causing your problem. In the summer that will dry but winter is cold so it just stays there.
I had an old '91 Camry until a couple years ago, did exactly what you're talking about. All the windows fogged up. The heater had to stay on high and the driver's window would be cracked just to keep up. I never did find out where it was coming from.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is online now   Reply With QuoteReply With Quote
Old 12-18-2022, 04:26 PM #10
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
2017 SR5 base 24K
Hi sunnah...,
In addition to the advice that there may be a moisture leak in the cabin, have you checked the "Front Windshield Seal?"... there have been issues with that in the past(?)! You can start by drying the moisture near the dash and glass with a towel. Then, using a garden hose, spray the entire outside of the windshield"...generously!"
Look for evidence of water droplets on or near the dash area. I would also do the same to the sunroof if the windshield checks out fine! As far as your HVAC System... you can start by getting the engine warmed-up to normal. Turn the front windshield defroster on FULL-FAN w/Temperature on HIGH.
It should feel Hot; NOT luke warm! Also check the air's direction to be sure it's blowing up at the glass on both-sides (D and P), and the fog is dissipating as needed! Next, I would touch the carpet near all of the door sills and check the door drains; you can see them under the doors... use a small Phillips-head screw driver to make sure the holes are Unrestricted!
Best to you Mate! rig Cheers
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 12-18-2022, 06:21 PM #11
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Deodorant
Old 12-21-2022, 11:37 AM #12
lewdog998's Avatar
lewdog998's Avatar
No you cannot test condensation.....by its nature it would be pure water that evaporates and condenses, leaving the chemical component behind...at tleast that is my guess, not a chemist.
you could test actual pooling liquid or an active drip.
you can also taste it. just a dab...dont swallow it. (i know i know...)
Old 12-21-2022, 04:40 PM #13
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
On Car Talk they would always tell you that it left a residue behind after it dried out. It's usually pretty difficult to clean the inside of the windshield because of that. It tends to smear.
Rich
Kentucky
Old 12-22-2022, 08:03 PM #14
Buz06 Buz06 is offline
Buz06 is on a distinguished road
double check the recirculate switch, the feature should shut off automatically when defrost is selected.
Lord help me, I'm just not that bright. Homer Simpson
Buz06 is offline   Reply With QuoteReply With Quote
condensation , dropping , lot , rear , windshield
Condensation on inside of headlights Pyral 3rd gen T4Rs 2 01-10-2022 10:31 AM
Extreme inside windshield condensation Sky 5th gen T4Rs 13 01-19-2020 07:59 PM
Condensation inside windshield kolelt 3rd gen T4Rs 61 02-23-2018 06:57 AM
Hissing sound inside the cabin Paul06Sport 5th gen T4Rs 7 09-12-2016 09:05 PM
Noise from inside cabin 5gen Duke562 5th gen T4Rs 16 11-13-2014 01:21 PM
