Old 12-16-2022, 06:13 PM #1
itr1275 itr1275 is offline
itr1275 will become famous soon enough itr1275 will become famous soon enough
Exclamation TPMS Warning Light?
It's been a little cold, but not freezing and I get a warning light for the spare tire pressure is low. In the pic it's 52F, barely below sweater weather.
The spare is at 34 PSI and the others tires (the ones I drive on) are @32 PSI.
I understand you probably want a bit more air in the spare, but it's not actually low.
Is this an error or just some SW guy likes warnings?
TPMS Warning Light?-tpms-jpg
itr1275 is offline   Reply With QuoteReply With Quote
Old 12-17-2022, 01:44 PM #2
The light stayed on even when it was 60F outside and magically turned off last night.
Any takers, in sights, should I be concerned, has anyone seen this?
Old 12-17-2022, 02:12 PM #3
meltdown meltdown is offline
meltdown will become famous soon enough
My guess would be there is a problem with the sensor. We have a work truck that has had a sensor go bad multiple times. The dealer or a trusted tire shop should be able to figure it out.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
Old 12-22-2022, 06:28 AM #4
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is a jewel in the rough rigtec is a jewel in the rough rigtec is a jewel in the rough rigtec is a jewel in the rough
rigtec's Avatar
Real Name: Greg
Hi itr1275,
I would just check ALL 5 tires for proper psi B-4 spending any $$$,00, ...And, I would disconnect the battery (minimum of 4 HRs); to Re-Set the Main Body ECU-Compu Net! That should do it! If it doesn't, then I might swap the TPMS valve stems... bc that could be the trouble... but the battery disconnect is easier; Please let us know how you make out!
Best to you, ~rig~ Cheers!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 12-22-2022, 03:00 PM #5
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light 1000MPH is a glorious beacon of light
1000MPH's Avatar
Your spare dropped below the low pressure threshold is all. Most likely due to an overfilled condition that set the threshold too high. Pump that sucker up to max allowable PSI.
2010 Trail - 128k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-22-2022, 07:57 PM #6
Buz06 Buz06 is offline
Buz06 is on a distinguished road
You might try resetting the TPMS system for the current pressures and see if you get another warning, It may be that the system was set when the spare was at a higher level and it eventually bled down to the trigger level.
For a while I was experimenting with different tires and pressures so I reset the system several times. It's easy and the procedures are in the manual.
Lord help me, I'm just not that bright. Homer Simpson
Buz06 is offline   Reply With QuoteReply With Quote
light , low , psi , spare , warning
2008 4Runner Parking Brake Warning Light & ABS Light Flicker Simultaneously sant6236 4th Gen T4Rs 52 01-07-2020 06:34 PM
TPMS warning light flashes after 1 hour of driving MarkieG 4th Gen T4Rs 2 07-30-2019 02:02 PM
TPMS (4th gen) - flat spare tire, no TPMS light pipspeak Engines / Suspension / Wheels / Tires / Audio / Accessories 1 04-17-2018 11:31 PM
No TPMS, TPMS light on LandCruiser General Discussions 7 02-17-2016 01:52 PM
A/T oil temp warning light and battery warning light concern arki01 3rd gen T4Rs 3 05-23-2015 10:45 PM
