Old 12-23-2022, 12:28 AM #1
clanger clanger is offline
clanger is on a distinguished road
Exclamation Rusted Tailgate Latch
2014 4Runner SR5
Tailgate latch area has major rust happening and didn’t get this bad till this fall. I had an issue with the glass falling down due to rust on the hangar and motor dropping it this summer. Now I found this after removing the trim piece that covers up the latch assembly. Really bummed it got this far.
This area inside the tailgate is just prone to excess moisture in my 4Runner. Clogged weep holes along the bottom doesn’t help either. I’m worried it is too late but wanted to get your thoughts. Hoping it might be salvageable.
My initial thought is using a rust converter and sanding to try to save it. Inside and out of the tailgate assembly. Worse case I’ll run until it breaks off and buy just the tailgate body part. Paint and re-assemble it myself.
2014 Toyota 4Runner SR5 - Black
clanger is offline   Reply With QuoteReply With Quote
Old 12-23-2022, 12:47 AM #2
GreenMountainOwl GreenMountainOwl is offline
GreenMountainOwl is on a distinguished road
I didn’t bother to try to save mine.
I read somewhere that only two manufacturers make the assemblies, despite branding and price differences. So I went with the cheapest imported eBay latch assembly about six months ago and it’s been fine.
GreenMountainOwl is offline   Reply With QuoteReply With Quote
Old 12-25-2022, 12:49 PM #3
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
I replaced mine with OEM after 8 years and rusty latch mechanism before it failed and locked up.
<<<< is offline   Reply With QuoteReply With Quote
Old 12-25-2022, 01:07 PM #4
Did you replace just the rear tailgate assembly and moved everything over? There are sales right now on the tailgate only for $625 which isn’t horrible. I think I’m able to fix it myself but waiting for winter to end.
Part below:
Old 12-25-2022, 11:01 PM #5
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
I JB welded the tailgate and lubed up the latch with PB Blaster. I'm not about to replace an entire tailgate just based on this.
However-- I will say that if it was to eat things out enough the latch would have nowhere to bolt to, then that's an issue.
Sent from my SM-S901U using Tapatalk
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 12-28-2022, 11:09 AM #6
<<<<'s Avatar
<<<<'s Avatar
My locking mechanism was rusty, which I replaced. Tailgate is fine and didn't need to be replaced.
Old 05-21-2024, 11:25 AM #7
Dimsdale Dimsdale is offline
Dimsdale is on a distinguished road
5th gen hatch lock rust
I have the same issue. The rust came from the inside out, so when I saw it, it was already too late. The rust has rapidly progressed to the point that I had to buy a new hatch and lock.
Looking at the plastic water shield on the lock, is it not plausible that the open cell foam around the base of the lock at the door is holding water/sale and causing the corrosion? The rust pattern matches the shape of the foam covered shield. I am debating on removing the foam, since it seems to be causing more problems than it stops. I am going to Fluid Film the daylights out of the inside of the door as well.
See attached.
Rusted Tailgate Latch-20240211_161029-b-jpg  Rusted Tailgate Latch-20240508_114047-b-jpg
Dimsdale is offline   Reply With QuoteReply With Quote
Old 05-21-2024, 11:56 AM #8
Humble Leader's Avatar
Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold
See attached.
I take the hand grab holders out of from the liftgate and spray fluid film in that way. you can use the drain holes too but you can get a lot more reach going through the hand grab spots. for anyone that doesn't want to remove their rear hatch this will really get good covering on that latch area too
I also do the doors as well
Old 05-21-2024, 07:46 PM #9
Funny seeing this post now. A year later I traded it in. Largely (but not 100%) due to this issue.
assembly , inside , latch , rust , tailgate
Rusted rear latch change whole door ? mike4Runner2003sr5 5th gen T4Rs 9 08-10-2022 01:17 PM
Rear latch lock rusted. calcrc 5th gen T4Rs 5 07-05-2017 10:09 AM
Rusted Out Latch mustangaustin34 3rd gen T4Rs 11 05-09-2013 10:46 AM
4th gen tailgate latch deebs For Sale: T4R Items 0 01-04-2013 09:39 PM
Rusted out 1st gen. tailgate. mechagouki Classic T4Rs 12 10-19-2011 12:05 PM
