Old 03-25-2022, 09:37 PM #1
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
Engine hood strut replacement
I crawled the forum and was not able to find a post about replacing the hood struts.
1. Does Anyone have the part number handy
2. How to? nothing on youtube. Only for the 4th gen
For those who are wondering. I'm at 125k miles.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 10:05 PM #2
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Go to partsouq.com and put in your vin and browse body category. Get p/n and order from mcgeorge. Have a trusted and sober helper hold up the hood while you unbolt the old ones and put on the new ones. There's most likely cheaper ones available from liftsupportsdepot.com and other places. Not sure how exactly the top disconnects but it looks like you start with sticking a screwdriver in that slot I would assume.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 10:35 PM #3
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Did the OEM struts last long enough that you’d like to buy more OEM ones, or perform so poorly that you’d consider aftermarket ones?
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 10:51 PM #4
Pavement Tested Pavement Tested is offline
Pavement Tested will become famous soon enough
Specifications for the replacement hood lift struts on Rock Auto for a 2010 4Runner show that the strut is ~10.3" when fully compressed, ~16.5" when fully extended and have a lifting force of about 65 lbs.
They have ball and socket or cup type ends with a spring retaining clip. To get them off you need a sturdy pick tool or a small flat screwdriver. Just pry the retainer springs off the ends and they'll come off the ball studs.
To install the new ones you just press the socket or cup, with the retainer spring on it, down onto the ball stud and they will snap into place.
Please note (although it shouldn't need to be): You must support the hood when removing the old struts.
2016 Trail Attitude black. 1.5" unknown brand lift, 275/70-17 Toyo Open County A/T on DX4 Rebel 17x8.5 -6, bull bumper, light bar, skid plate by Amazon, DD fogs, TRD roof rack by Craig's List, Accessorides remote start kit
Pavement Tested is offline   Reply With QuoteReply With Quote
Old 12-28-2022, 02:09 AM #5
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
Bump ...... can't figure out which parts need to be replaced? Just the struts or the entire assembly? Does anyone replace and have info?
Dual Battery Thread
Old 12-28-2022, 10:03 AM #6
313n703's Avatar
313n703 313n703 is offline
313n703 is on a distinguished road
313n703's Avatar
I believe only the struts needed to be replaced, unless you need to replace the attached parts on the hood and fender.
I also need to replace the ones on my 2010. I found the OEM part numbers, 534500W190 (Left) and 534400W230 (Right). There are also aftermarket ones for cheaper, like Strong Arm Lift Support. I may just stick with the OEM ones, since they lasted 12 years.
MGM OG 5th Gen
313n703 is offline   Reply With QuoteReply With Quote
Old 12-28-2022, 11:35 AM #7
Humble Leader's Avatar
I used these part #s about a year ago to replace my hood struts. they are labelled as separate part #s but really they are the exact same. must be because you can order the assembly as well which is different for each side
OP:
very easy to replace. get a squeeze or trigger clamp for wood working and prop the hood and use the clamp under the chamber to stop the hood from closing. use a flat head screw driver and pry the little metal clip on the top and bottom of the strut where it seats, then give a good tug and it will come out. replace and push the clips in on the new strut to lock in place. 2 minutes per side. if you've replaced your liftgate struts it's basically the same exercise
Old 12-28-2022, 09:59 PM #8
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
If you aren't stuck on OEM you should be able to get struts at your local auto parts store.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 12-29-2022, 01:57 AM #9
Jeremy556's Avatar
Jeremy556's Avatar
I just replaced my hood struts a couple months ago. I can't speak to their long term longevity, but I couldn't resist their price vs. OEM. ‎S80T-2337 <$20 shipped from Amazon. IIRC OEM was >$200.
I'm normally a 100% OEM parts only guy, and normally don't even consider aftermarket parts, but being a non-important component the price difference is hard to ignore.
It would not surprise me if these fail in a month or two and I end up having to buy OEM anyway, as that's usually how trying to save money on aftermarket parts works out, but we'll see.
engine , handy , hood , number , youtube
Hood Lift Strut Mod mtbtim 3rd gen T4Rs 19 12-17-2019 12:45 PM
FS: 3rd Gen Hood Strut Kits, $79 4Runner4Leon For Sale: T4R Items 0 08-30-2019 04:00 PM
Hood Strut Mod for 3rd Gen octanejunkie 3rd gen T4Rs 34 01-31-2019 01:51 PM
Hood Strut Replacement Procedure sealbeams 4th Gen T4Rs 6 02-20-2015 03:47 PM
Hood Strut duffguy808 4th Gen T4Rs 1 06-15-2007 01:42 PM
