Old 01-01-2023, 04:21 AM #16
SurfToy's Avatar
SurfToy SurfToy is offline
SurfToy is on a distinguished road
SurfToy's Avatar
How about leave the 4runner at home and tow something lighter that is not specifically prohibited from doing so (per the manual)?
2014 Trail Premium | White | KDSS | Moonroof | Sliding Cargo Tray | Bilstein/Wheeler 2.5" lift with airbags | Ironman Offroad UCAs | BFG K02 255/75R17 | Sprint Booster
Previous: 2019 TRD OffRoad Premium, 2006 SR5 V6 2WD
SurfToy is offline   Reply With QuoteReply With Quote
Old 01-01-2023, 02:23 PM #17
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
Originally Posted by ajohansson View Post
i have no desire to disconnect drive shafts or dolly. Transfer case in neutral and put it in park is the plan. Just got to figure out the push to start thing if I end up getting a newer model. could put in the ADD disconnect switch easily and just leave in accessory if thats what I need to do.
I have a PTS and in accessory, it shuts off after 20 minutes. I would double check that the steering wheel lock also does not re-engage after the radio shuts down.
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 01-03-2023, 11:22 AM #18
ajohansson ajohansson is offline
ajohansson is on a distinguished road
found a guy at work with a push button TRD we shall see!
ajohansson is offline   Reply With QuoteReply With Quote
Old 01-03-2023, 11:31 AM #19
4800 lbs is a tad heavy for a toad but not crazy. the new Class C E450 has some legit towing capacity and gcvw. they put a 7000 lb hitch on there. I really could care less what the bean counters at toyota put in their manual. It can be done no issue. I ran my 7.3 excursion and F350 on waste vegetable for 300k miles combined and both still run today No issues with injectors etc. I am not afraid to do stuff if its done correctly.
Old 01-03-2023, 11:58 AM #20
guy at work confirmed with a video what you said. He is starting the timer now.
Old 01-03-2023, 01:38 PM #21
After 30 mins he checked, times out, steering wheel locked.
Now off to how to over ride the ACC when I do this.
I am already planning on a switch to to kill power to the ADD so I could add another relay that could keep ACC power on using the same switch.
I was going to see if AOB would make me a "Tow Mode" switch.
When I tow this thing hit the switch and it kills power to the ADD, then I can put the transfer case in Nuetral with out it locking the front.
Wiring diagrams here I come.
Old 01-03-2023, 01:56 PM #22
did a quick search and there is a thread in the 5th gen forum about keeping the ACC on indefinitely.
Is there any way to make accessory stay on longer?
Folks are saying if you kill the rig in neutral then push the button without foot on brake it will keep the acc on indefinitely.
So this maybe my solution. got my buddy testing this for me now.
Start truck put on P-Brake - put in neutral - kill truck - hit push to start with out foot on brake. Put back in park. set timer and see what happens in 30 mins.
Old 01-04-2023, 03:57 AM #23
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
If you keep it in ACC mode while towing won’t there be concerns with battery drain? I suppose maybe just parasitic draw
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 01-04-2023, 06:32 PM #24
So when I do this I am going to add a 7 pin under the front airdam. This will be used to tie into the 4runner lights. Following this guys tutorial.
Toad/Dinghy Wiring - RV Headlights
So I will make sure I run a line from the 7 pin hot to the battery to help keep it charged but with everything off its gonna be so minimal.
So plan is just to leave it in nuetral now as we know that works I really dont have to put it in park as with the transfer case in neutral it does not really matter what its in.
push , reply , started , version , wheel
Steering wheel lock (push button start) 'immobilizing the engine? rigtec 5th gen T4Rs 5 01-08-2020 11:05 PM
Is my 4th Gen '08 v6 supposed to have a steering wheel lock? Seymore Butts 4th Gen T4Rs 1 02-13-2018 10:27 PM
Electric Steering Wheel Lock? juiceboxer 3rd gen T4Rs 1 12-09-2012 11:49 AM
How do I lock my steering wheel? CodyX36 3rd gen T4Rs 10 02-25-2012 11:52 PM
no steering wheel lock jwyshrek 4th Gen T4Rs 9 02-08-2006 08:43 PM
