Old 01-03-2023, 01:09 AM #1
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
High Pitch AC/Heater Noise
Hi All
Recently when I use the AC/Heater fan there is a high pitch noise. The higher the fan speed the louder it gets. I checked the forum and most said the noise is caused by debris in the blower. I found a good video that shows how to remove it. 2016 Toyota 4 Runner Blower Motor Problems / Fixes - YouTube
When I took it out I found some debris and thoroughly cleaned the blower and inside the housing. Before I put it back in I tested the fan outside the housing and there was no high pitch noise. However, when I put it back in the high pitch noise was still there. So at this point Im not sure where the problem. Is there some debris inside the duct somewhere or is it a bearing issue in the blower and its only noticeable when inside the housing? I was wonder if there is some other way to trouble shoot the problem before I go out and buy a new blower.
Thanks
Lexington is offline   Reply With QuoteReply With Quote
Old 01-03-2023, 05:21 PM #2
DEUS-MACH1NA DEUS-MACH1NA is offline
DEUS-MACH1NA will become famous soon enough DEUS-MACH1NA will become famous soon enough
I too cleared the debris and re-installed but ended up just replacing it. Everything I've read consistently say the bearings just go tits up.
1yr in on the new motor and it's been fine with no more of that dreaded high-pitched whine to add to the cacophony of cabin sounds (roof rack + gear wind noise, back seat driving wife, etc)
DEUS-MACH1NA is offline   Reply With QuoteReply With Quote
Old 01-03-2023, 11:38 PM #3
jp.vegas jp.vegas is online now
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Let me know if you find a fix for that last one.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is online now   Reply With QuoteReply With Quote
Old 01-04-2023, 10:04 AM #4
sympley76 sympley76 is offline
sympley76 is on a distinguished road
lol, or a 3 year old trying to sing along paw patrol with the wife... even the cough, cough premium JBL can not drown out that sounds...
sympley76 is offline   Reply With QuoteReply With Quote
Old 01-04-2023, 03:22 PM #5
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
My blower is so dang loud it's ridiculous. I really need to replace it
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 01-04-2023, 03:34 PM #6
Blundberg5 Blundberg5 is offline
Blundberg5 is on a distinguished road
My 2019 had this issue too, dealer replaced the blower under warranty around the 3 year mark. The sound drive me crazy.
Blundberg5 is offline   Reply With QuoteReply With Quote
Old 01-05-2023, 04:59 PM #7
Humble Leader's Avatar
preferably one that doesn't require a divorce lawyer
Old 01-16-2023, 02:45 AM #8
Lexington's Avatar
Lexington's Avatar
Update.
I ended up buying a new blower and now the high pitch noise is gone. Very quiet now.
It very easy to replace it yourself.
1. Remove cabin air filter in the back of the glove box. Remove any debris and replace filter if needed.
2. Underneath the glove box pull off bottom cover. Very easy.
3. Unplug power cord. The release button is a bit stiff and you mag need a flat head screwdriver to push it in while you pull.
4. Unscrew the 3 screws. You can use a ratchet with a 8mm Socket or a T-25 torque screw head. The back screw is a little difficult to reach. You will either need a very short screwdriver or a small ratchet to get it out.
It took me about 20 min.
Here’s a video link.
https://www.youtube.com/watch?v=d5qBWsZEYnw
Old 01-16-2023, 02:29 PM #9
Originally Posted by Lexington View Post
Update.
I used that same link haha. although if you have a limited which I do you may have an orange LED attached to the trim piece you pop down. be careful you don't break the wire if you do when pulling that panel down. you can remove the LED from the housing but I kept it in there and just rotated and moved the panel to the side
blower , debris , fan , noise , pitch
High pitch noise from dash T4Rjr 4th Gen T4Rs 3 04-14-2023 05:16 AM
99 4R - engine high pitch noise mznobull 3rd gen T4Rs 3 11-18-2018 01:50 PM
Another Noise!!! High Pitch while moving.. chris_1001 5th gen T4Rs 3 09-17-2018 10:57 AM
High pitch noise from engine? Might be normal alext72888 5th gen T4Rs 9 03-07-2016 07:01 PM
high pitch whining noise at 65 mph. jpd4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 2 09-09-2014 06:19 AM
