Old 01-08-2023, 01:43 AM #1
sigepbiker's Avatar
sigepbiker sigepbiker is offline
sigepbiker is on a distinguished road
sigepbiker's Avatar
Skid Plate Frame Nut
Attempted to remove my RCI Front Skid plate to clean them up. When removing the passenger rear bolt, the threaded nut in the frame spins with the bolt, not allowing it to loosen up to remove the skid plate.
Any suggestions on how to hold the nut that's inside the frame cross member?
Suggestions on repairing the threaded hole on the frame?
@JoshP 767 - please don't tell me I'm the first to encounter this...
Skid Plate Frame Nut-skid-bolt-jpg
2016 Trail Premium Tires and sliders and some interior mods...
2005 SR5 Silver mod list
FOR SALE: Rear Diff Breather Fitting; 4th Gen Center Diff Switch w/ pigtails
sigepbiker is offline   Reply With QuoteReply With Quote
Old 01-08-2023, 01:48 AM #2
Jeremy556's Avatar
Jeremy556's Avatar
Cut the bolt off, pull the broken off part out of the top, and replace with a rivetnut. Use antisieze when re-assembling.
Old 01-26-2023, 10:55 PM #3
agoff71 agoff71 is offline
agoff71 is on a distinguished road
You could try using a screwdriver or pry bar to put downward pressure on the bolt, this might hold the nut in place as you try to loosen the bolt.
Sent from my moto g stylus 5G (2022) using Tapatalk
agoff71 is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 02:11 AM #4
bayaz bayaz is offline
bayaz will become famous soon enough
I drilled it out, and put a rivnut.
bayaz is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 11:38 AM #5
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
If the nut is rotating and a bolt won't unscrew (see the picture), then how do you drill it out? Even if there is not a bolt in the nut, you still can't drill it out because the nut will just rotate with the drill.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 12:29 PM #6
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
From personal experience: impact wrench is not your friend while removing bolts from frame. It'll bust tac weld on the nut inside the frame right out every time. PB tread blaster and steady force on breaker bar is the ticket. As for the one you have broken off, saw it off, fish bits out and drop a new nut in (stick nut will work best) or as mentioned before rivnut. G.L.
<<<< is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 02:07 PM #7
I drilled out a larger hole in the frame. You gotta do that to put in a rivnut.
The hole is larger than the existing captive nut, so you just displace it with the drill and then use a magnet to fetch out.
Old 02-03-2023, 05:12 PM #8
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
This is one of the few bad designs with 4Runner. Mine broke because the guy who was changing my oil used a impact gun to remove the skid plate.
A rivet nut will work. My only concern is if I have another guy use a impact gun removing my skid plate will the rivet nut hold? Because of this concern I decided to welding two nuts on top of the frame. I had to buy 2 new long bolts that would fit.
For the Tacoma skid plate they added a removable access plate so you can change the oil filter without having to drop the entire skid plate. I have no idea why Toyota didn’t do the same for the 4Runner.
Lexington is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 08:33 PM #9
I use an impact now. As long as it’s 1/4 inch you’re good. That said, I’ve replaced rivnuts before too but like because of off-road abuse.
Old 02-03-2023, 08:56 PM #10
Lexington's Avatar
Lexington's Avatar
I dont follow. As long is what is a 1/4 inch?
Old 02-04-2023, 02:08 AM #11
Glenn Goodlett's Avatar
Glenn Goodlett Glenn Goodlett is offline
Glenn Goodlett will become famous soon enough
Not my video and have no association with it. But it is what I'll do when mine give out.
Repairing Broken Skid Plate Bolts 5th Gen Toyota 4Runner - YouTube
2020 Army Green TRD Pro
2007 FJ
Glenn Goodlett is offline   Reply With QuoteReply With Quote
Old 02-04-2023, 04:00 AM #12
1/4" drive impact wrench. Not sure I have ever seen one. But I do have a 1/4" air drive wrench.
Old 02-05-2023, 12:44 AM #13
I use a Milwaukee with a replaceable bit, so I slide in a 1/4”. Problem with most shops, including Toyota dealer, is that they’ll use 1/2” but that comes on impact used to take off lug nuts - that’s way too much torque.
frame , nut , plate , skid , threaded
Upgrade skid plate hardware to fix broken bolts & in frame nuts SirWilliamGoes 5th gen T4Rs 0 12-19-2022 01:02 PM
5th Gen Genuine Toyota OEM front skid plate (not a PRO skid plate) - $50 (North Seatt SI2IS2T4R For Sale: T4R Items 0 05-27-2021 12:14 AM
*UPDATE* I have purchased a skid..98 4Runner front skid plate WTB TraumaHawk Free 4 11-11-2020 11:46 PM
frame bar for skid plate giovannie23 3rd gen T4Rs 13 11-05-2016 09:24 PM
How to remove skid plate Nut in frame? Greydog 4th Gen T4Rs 7 10-12-2013 11:36 AM
