03-18-2013, 10:58 PM
5th Gen Fender Mod
I Searched and came up empty on Fender Mod to fix 285/70/R17 tire rub in Trail. All seem to refer to the Mod but no actual post on how it's done that I can see. Can it be done without trimming? Industrial heat gun to re-mold plastic in high places? Any help would be great. Thanks
03-18-2013, 11:05 PM
Real Name: Gary
Real Name: Gary
It's in the stickies. http://www.toyota-4runner.org/5th-ge...tml#post759604
Max + caster to bring wheel forward and liner mod= no rubbing with 33's like your 285/70/17's . No need to cut anything or heat gun til you go bigger then that.
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
. ...........Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
03-19-2013, 09:03 AM
Real Name: 2016 Member of the Year
Originally Posted by harper7
I've looked at that danged pictorial countless times on how to move the fenders and I can never make heads or tails about what's being moved or how.
Ryan - KC2VQG
- 2020 4Runner TRD Off Road White
- 2016 4Runner TEP Black (Sold)
- 2012 4Runner Trail Edition Black (Sold)
- 2008 4Runner V8 Sport Edition Black (Sold)
03-19-2013, 09:09 AM
Real Name: Um, Phil?
This will have the side benefit of improved steering stability. My SR5 wandered a bit until I did this. Get the caster to at least +4*.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
03-19-2013, 09:50 AM
5th Gen Moderator
5th Gen Moderator
I was in that same boat for a while too. Once you get down there and see the room for the fender liner to move forward, and away from the tires, you'll understand how you can make new holes and tighten the bolts to keep it there. Props to
@ harper7
for this because it's an awesome trick
Originally Posted by 7harper
First 5th with real CO's
2017 White TRD OR, Icons, BFG Mud-Terrains, Konig Countersteer, Retro Headlights, Gobi stuff
03-19-2013, 10:36 AM
Mine rub with Nitto TerraG is minimal and only at the plastic piece that covers mud flap from the front? What's behind that? Any ideas on how to move or reshape that piece?
10-22-2016, 09:16 PM
Real Name: Kristian
Real Name: Kristian
SR5 Fender Mod photos
Did this mod for my 2011 SR5 and thought I'd share some pics since it looks a little different than the TE.
I happened to have my bumper off already so you can see the top side.
After pushing the fender forward 3/4" the front 'inner' corner seemed to be pulled in slightly. To counter this I moved the two screws that line up off the corner a bit.
After moving the fender forward you see part of the outer trim hangs over a bit. I cut it off with my dremmel.
All photos are drivers side.
11' SR5 Gray. Toytec Ultimate lift with OME rear springs, 17" MB wheels, 285/70 Duratracs, N-Fab Nerf bars, plasti-dip most chrome.
03-17-2017, 09:28 PM
Additional or alternative way to mod the fender liner?
Hey all, new poster, so I can't start a new thread, but maybe it should be added to this one anyway?
I did the "traditional" fender liner mod on a 5th gen Limited (2016) but to make a long story short, I still got rubbing after swapping my factory 20" wheels with 20x8.5's Black Rhino's with OEM ET15 offset and adding Hankook Dynapro 275/55/20's.
I found a solution that may work well with or in place of to the fender liner mod described already in the forum. It may even be easier.
Should I post here or ask the moderators for the ability to start a new thread?
'16 4Runner Limited, Black.
03-17-2017, 10:01 PM
Post it here... for now.
10-19-2017, 12:51 PM
I know this is an old thread. Posting this video for new people searching.
Shows what I had to do to fit 285/70/17 KO2s on my 5th gen 4runner. 2016 Trail Edition.
I basically just moved the front fender liner up and then zip tied the mud flap tight against the fender liner.
https://youtu.be/ApZ1_K77zMc
11-07-2017, 01:01 AM
Jake,
Killer video. I had put the same KO2s in the same 275/70/17 size you have about a month and a half ago and had zero rubbing. Over the weekend I got a sweet deal on some used ATX Slot wheels in a 17 x 9 and switched the tires over. Definitely had rubbing. Took all the mud flaps and did the bumper trim but wanted to find out how to easily do the fender move and found your post. Glad I did! I'll get on it first thing tomorrow. Thanks!
2017 4Runner TRD Trail Premium
275/70/17 BFG KO2
Lamin-X Fog Mod
Yakima Roof Rack, Inno Shadow 16
11-09-2017, 10:51 PM
Real Name: Bob
Real Name: Bob
Thanks for the video Jake. I'm a stock height guy as well. Great solution cuz I dig the mudflaps.
2017 TRD Off Road Premium Super White | TRD Pro Kit | C4 Fab Rock Sliders | RCI Partial skidplate | ARB Breather | Goodyear Wrangler Duratracs (265 70R17) | BORA 1.25" spacers | Baja Designs Squadron Pro Wide Cornering | LED Bulb swap | Morimoto HID Low beams
If your front mudflaps are still on you aren't modding hard enough.
02-27-2018, 01:26 PM
Real Name: Phil
Real Name: Phil
@ Angonemoto
, hey, another Chicagoan here. I see this post and then I see, "If your front mudflaps are still on you aren't modding hard enough" in your signature. Sarcasm? Or did adjusting them not work out so well for you?
I just replaced my trail wheels with TRD Pro wheels with my existing 275/70r17 K02s and now I rub! This is before my spidertrax spacers even go on. Just trying to sort through what works/didn't work for folks with a similar build.
2016 TEP w/KDSS - Total Chaos Expedition +2 Long Travel, Accutune Fox DSC 2.5" LT Coilovers & Accutune Fox 2.5" modified Tundra rears, ARB Summit Bumber, Nguyen Works Rear Bumper, DR_KDSS errything (switch, clamps, front brackets, BOTCK), RCI Armor, BajaRack, Baja Designs, Sumosprings bumpstops, 17"x9" +0 Enkei RPT1's, Yokohama Geolandar G0003 285/75/17 (34.1"), 4.56 Nitro gears, +random bolt-ons
02-28-2018, 11:24 AM
Real Name: Bob
Real Name: Bob
I did get rubbing off road
Hi there,
With my 1.25 spacers, the het mod on the flaps and the big cleats on the stock size Wranglers I got some initial rubbing at full lock pulling out of the garage and in parking lot turns. I didn't mind that much, but in the more rougher terrain when the suspension articulated it rubbed more. I pulled them off after that. I am sure you can manipulate the flaps to work but I still think there will be minor rubbing when off road or crawling minor obstacles.
Remember, I had the liner repositioned and the bumper trimmed as well.
12-12-2023, 01:54 AM
https://www.youtube.com/watch?v=ApZ1_K77zMc&feature=youtu.be
Thanks for the video, clearest description I've found.
