Old 01-11-2023, 02:31 PM #1
dubveeT4R's Avatar
dubveeT4R dubveeT4R is offline
dubveeT4R is on a distinguished road
dubveeT4R's Avatar
Another Suspension Knocking Post
Hi, all. I have searched the forum and online, but have not come up with a satisfactory answer, so apologies in advance about yet another suspension-related knocking post.
'22 ORP with KDSS, 3,500 miles, purchased new in September. When going over uneven pavement or a series of bumps, I am getting a knocking sound from (I believe) the rear of the vehicle. It seems to be more noticeable when the speed is 15 mph or so, and sometimes when turning left. It sounds like a suspension component - it's not just one "clunk", but a knocking sound, almost like the spare tire or something is loose. (I checked the spare - it is not.) Lower temperatures (32F and lower) seem to make it worse.
Any suggestions for my visit to the dealer's service department?
dubveeT4R is offline   Reply With QuoteReply With Quote
Old 01-11-2023, 10:24 PM #2
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
Are the jack and its toolkit strapped tight?
Are the grease points lubricated on the rear drive shaft?
If you added a lift. is the KDSS swaybar touching the panhard bar?
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 01-12-2023, 09:56 AM #3
dubveeT4R's Avatar
dubveeT4R's Avatar
Jack and toolkit are tight. No lift - all stock. It’s only a little over 3 months old, but I can check the grease fittings on the rear driveshaft. It sounds like something knocking back and forth a couple of times in the scenario described.
Old 01-12-2023, 01:08 PM #4
MNT_GOAT MNT_GOAT is offline
MNT_GOAT is on a distinguished road
I also hear this clunking noise particularly when it's very cold. I also have not been able to identify the source. I sounds exactly like a loose jack in the back, but everything is tight back there. My 4Runner is a stock ORP with no KDSS.
MNT_GOAT is offline   Reply With QuoteReply With Quote
Old 01-12-2023, 01:25 PM #5
tpete tpete is offline
tpete is on a distinguished road
Can you try to maybe take the jack and components out and see if the "clunk" is still there to narrow it down. Then maybe take off the spare and see if you still hear a noise? Sometimes process of elimination will narrow it down.
tpete is offline   Reply With QuoteReply With Quote
Old 01-12-2023, 10:59 PM #6
Too Many Hobbies Too Many Hobbies is offline
Too Many Hobbies is on a distinguished road
Similar issue in front
I was just about to ask about a similar issue I am having but it is with the front . When it is cold and driving after sitting for a while it sounds like maybe shock tops or something. Thats from my previous experience with noises in the automotive service side with cars. Maybe there is something to do with your rear shocks.
Too Many Hobbies is offline   Reply With QuoteReply With Quote
Old 01-12-2023, 11:18 PM #7
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
if your vehicle is stock, take it to the dealer for warrantee work.
Old 01-19-2023, 11:56 AM #8
dubveeT4R's Avatar
dubveeT4R's Avatar
I still have not been able to track down the sound, but after paying closer attention, it sounds like it is coming from the front suspension. I re-read a few posts, and it seems that the problem areas could be upper control arm/lower control arm bolts, or the sway bar bushings. It seems unlikely with a new vehicle, but at least this is somewhere to start to check when it goes to the dealer.
Old 01-19-2023, 12:20 PM #9
John in NC John in NC is offline
Real Name: John
John in NC will become famous soon enough John in NC will become famous soon enough
Real Name: John
While you are there have them make sure your prop shafts are lubed, mine were about dry when I got my clunk solved. Seems some are never lubed from the factory.
John in NC is offline   Reply With QuoteReply With Quote
Old 01-20-2023, 12:17 PM #10
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I would check you sway bar bushings.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 01-20-2023, 02:31 PM #11
make sure the battery is tight. i had a knock as well, turned out to be the battery tie downs were loose. if you wheel alot this will happen as the hooks will elongate the hole in the mount, letting the nuts loosen up.
knocking , lower , sound , spare , suspension
Suspension knocking Rob_G 5th gen T4Rs 2 03-06-2017 09:56 PM
WhAt could make knocking noise in suspension kacper 4th Gen T4Rs 8 07-20-2014 07:50 PM
Suspension knocking, HELP!! Robmills72 Classic T4Rs 3 04-29-2013 08:42 AM
Chattering/knocking/vibrating from rear suspension tpirman 5th gen T4Rs 20 06-04-2011 12:21 PM
Knocking noise from right wheel/suspension area spo0587 Problems & Warranty Issues 4 04-09-2008 10:55 PM
