Originally Posted by scorpslvr
I need to replace one of the windshield washer nozzles because its not working properly (and I already tried putting a pin in it and that didn't work.) I believe its part #85035. On the Toyota parts listing it gives you three choices, depending on how you want the nozzle angled: 0 degrees, -2 degrees or +2 degrees. Does anyone know which one is for a normal, unmodified 2011 Toyota 4runner SR5?
Are you sure the nozzles are not adjustable? Most cars have adjustable nozzles, that is they are ball and socket arrangements. Put a needle, not a pin, in them then move the needle around and see if the ball moves. If there is a lot of hard water deposits, then they may be hard to move. You could practice on the old nozzle.
