Old 01-23-2023, 05:32 PM #1
JailbreakOverlandr JailbreakOverlandr is offline
Real Name: Richie From Boston
JailbreakOverlandr is on a distinguished road
45-60mph vibration heres the story.
Just left the arizona desert 4 days ago, because I had an appointment with ECGS to install a dana 60 in the rear. While driving I noticed my newly installed air bags looked wrong, Jumped under truck noticed one was blown out AND it moved the coil out of its seat. Now this truck is too heavy for my to reseat the coil but man did I try, broke an axe handle trying. anyhoo driving along etting gas over and over and in the very last 100 or so miles noticed a heavy vibration on accelaration and its between 45-60 after 60 its gone under 45 also gone. Im wondering did The wayward spring push my pinion angle off? or isit as simple as 37s need a rebalance. I did wheel az desert, big bear Ca. and a few other spots. Im used to vibrations popping up in my 80 series this is first time in 4runner. thanks heres some recent pics of build. Getting the entire rear axle replced tomorrow just may fix everything, but if it dosent I want to know what to look for now. thankss
heres a walkaround the youtuber cruisingtheland did last week in Ca.JailBreak Overland's 4Runner TRDPro full Walk around - YouTube
dual cases
trident 3 way shifter
supercharged
37s
total chaos plus 2 LT
etc etc etc
JailbreakOverlandr is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 05:57 PM #2
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Vibration in your butt or vibration in the steering wheel?
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 07:33 PM #3
spartacus's Avatar
spartacus's Avatar
dual cases
supercharged
37s
etc etc etc
I think you are correct. The vibration is either the drive shaft double cardon joint, thé u joint or the pinion bearing.
Old 01-23-2023, 08:16 PM #4
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
dual cases
supercharged
37s
etc etc etc
cant help u with your current issues, just want to say love the build man.
Old 01-23-2023, 11:14 PM #5
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
dual cases
supercharged
37s
etc etc etc
Did you get your spring back on the seat? The only way I know to do that is to unbolt the lower shock mount, then the axle will drop enough to reseat the spring.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-24-2023, 11:38 AM #6
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
dual cases
supercharged
37s
etc etc etc
In these situations where it’s hard to narrow down potential vibration sources I would go for the most common problem area. Which is your tires especially since you’re running MTs which are notoriously hard to balance. If all looks good there I would check drivetrain angles and as mentioned above your joints.
As an aside airbags are a terrible idea for any truck that sees heavy off-road use. They will fail it’s guaranteed. Go get OME 899s or if you need longer travel get some custom heavy springs made.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 01-25-2023, 10:25 AM #7
Xtremluck's Avatar
Xtremluck's Avatar
One additional thought just entered my mind. I believe you had custom driveshafts made for your dual case setup right? I would add those to the list of things to check (Balance, bolts on tight etc)
37s , coil , noticed , truck , vibration
Bad vibration @50-60mph WAY worse in 4-Hi redstar 3rd gen T4Rs 39 08-20-2015 05:11 PM
Vibration at 60mph. TRD Pro wheels and BFG KO2 Haydenatx 5th gen T4Rs 11 07-11-2015 11:01 AM
Low Hum/Vibration from Rear End between 55-60mph Sherwood4Runner 3rd gen T4Rs 0 07-10-2015 10:00 PM
vibration when gas pedal is realeased above 60mph fullcollapse318 3rd gen T4Rs 2 03-15-2011 07:39 PM
Break vibration/shake over 60mph KAM 4th Gen T4Rs 6 08-15-2009 11:44 AM
