Old 01-23-2023, 08:49 PM #1
Lexington's Avatar
Lexington Lexington is offline
Lexington has a spectacular aura about Lexington has a spectacular aura about Lexington has a spectacular aura about
Lexington's Avatar
Master Window Switch Cover
Hi All
I just recently ordered a new window master switch for my 2016 4Runner TRD Pro. I decided to replace the top cover of it as well since it is a bit worn. I went to my local dealer and the first guy looked for the part for quite a while but couldn’t find it. A senior guy step in and he found it in a short time. However, he told me that I can’t just buy that part by itself. If I want to that part I have to buy the whole door panel for about $800 bucks. That’s nuts! I don’t know if that guy was telling me the truth or not. So I’m wondering if anyone knows if there is a separate part number for this item or if there is a aftermarket place where I can buy just that part? I posted the picture below but for some reason it posted upside down and I can’t get it to post right side up.
If anyone can help I would appreciate it.
Thanks
Lexington is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 08:54 PM #2
djeepin djeepin is offline
djeepin is on a distinguished road
check interior trim kits, fiberglass of faux burlwood looks great, and cheaper
djeepin is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 09:37 PM #3
Lexington's Avatar
Lexington's Avatar
I would prefer to replace the original part but not a bad back up option.
Old 01-24-2023, 09:07 AM #4
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a name known to all lewdog998 is a name known to all lewdog998 is a name known to all lewdog998 is a name known to all lewdog998 is a name known to all lewdog998 is a name known to all
lewdog998's Avatar
Sounds like bs to me.
Did you see the actual drawing on his screen?
Hard to believe an interior trim part is combined as one part with a electrical part. Plus it does not make sense from an inventory stsndpoint.
Call another dealer to be sure.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 01-24-2023, 12:12 PM #5
fkheath fkheath is offline
fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light
Originally Posted by Lexington View Post
Hi All
Thanks
Does this help? 2016 Toyota 4Runner SR-5 Door Interior Trim Panel (Left, Front). BLACK - 6762035C62C0 - Genuine Toyota Part
fkheath is offline   Reply With QuoteReply With Quote
Old 01-24-2023, 12:31 PM #6
Hi All
Thanks
How about buying the switch with the bezel: 14-20 Toyota 4 Runner Driver Master Power Window 8404035080 Switch 907-5G2 Bx 1 | eBay
Old 01-24-2023, 01:40 PM #7
lewdog998's Avatar
lewdog998's Avatar
LKQOnline
LKQ is a good source and major supplier to body / repair shops
this for a 2019...but just plug in your specs and it will give you options.
Master Window Switch Cover-screenshot-2023-01-24-114148-jpg
Old 01-24-2023, 01:49 PM #8
lewdog998's Avatar
lewdog998's Avatar
OR.
I looked at the LKQ description and found an "alternate part numbers" tab...went to toyota parts online and found this
8404035060 - Door Window Switch. ENGINE, INSTRUMENT, PANEL - Genuine Toyota Part
Master Window Switch Cover-screenshot-2023-01-24-114814-jpg
Old 01-24-2023, 02:05 PM #9
Lexington's Avatar
Lexington's Avatar
I was thinking the same. I plan to go to another dealer today.
Old 01-24-2023, 02:10 PM #10
Lexington's Avatar
Lexington's Avatar
OR.
That is the Master Window Switch for the 2014 4Runner. I’m looking for the plastic cover that goes on top of it and not the switch itself. This plastic cover actually screws into the master switch. You would think this would come as a set but it doesn’t. Thanks for the LKQ link. Always glad to find other ordering option. However, before I can order that part I need to find the part number.
Here are some better photos. (Thanks FKheath)
Old 01-24-2023, 02:13 PM #11
Lexington's Avatar
Lexington's Avatar
Originally Posted by fkheath View Post
This is a nice back up option. Thanks! I was thinking of going to a pick and pull if I couldn’t find anything else.
Old 01-24-2023, 02:33 PM #12
Lexington's Avatar
Lexington's Avatar
This is what the dealer told me. He said it was showing no part number for the cover which means you can only get the part if you order the whole panel. I don’t want to spend $850 for one small plastic piece. Besides pick and pull your eBay option seems like the best deal.
Old 01-24-2023, 11:20 PM #13
Lexington's Avatar
Lexington's Avatar
I talked to a total of 3 dealers and they all said the same thing. The only way to get that part is to buy a whole door panel kit. I’ll pass. Two of the parts guys seemed a bit surprised because they said just about every other Toyota you can buy that part separately or that in comes with the master switch. They don’t know why they don’t do the same for the 4Runner.
So I guess my only option is at this point is a pick and pull or used parts from eBay.
I did send a email to Toyota today explaining the problem. Maybe they might find a part for me but I’m not holding my breath. I did tell them to sell the item separately or include it with the Master Switch.
Old 01-24-2023, 11:27 PM #14
lewdog998's Avatar
lewdog998's Avatar
Yeah I guess it makes sense....in my haste I did not see that the trim is a separate from the switch.
I am curious as to why its already worn...still a relatively young vehicle...physical wear or sunlight. Fwiw...I have my interior high touch areas that are smooth covered in ppf.
Maybe I should cover that part as well.
Old 01-28-2023, 04:28 PM #15
Hi All
Thanks
That switch cover does have a Toyota part number: 74232-X1D00,
But it apparently is not sold as a separate item by the Toyota parts department (thus any dealer). A quick Google search shows that part number can be erroneously confused with the switch itself.
Only way to get the cover seems to be a used switch with the cover attached.
buy , can’t , guy , part , window
Master Window Switch Problem segafan1989 3rd gen T4Rs 63 03-02-2023 08:21 PM
'98 Master Window Switch prockq 3rd gen T4Rs 1 07-05-2012 02:51 PM
Master window switch ALLNAMESTAKEN91 Classic T4Rs 0 02-19-2009 05:59 PM
FS 4runner master window switch typeIIIhilux Classifieds - buy & sell (no commercial ads please) 10 04-23-2008 08:56 AM
98 master window switch druuu88 Classifieds - buy & sell (no commercial ads please) 0 04-09-2008 12:57 AM
