Originally Posted by tb-av
OK, yes. Def. 11162 and I suppose the internals are on page 347 center page next to block letter "F".
6mm low insertion force.
Still can't quite figure how it comes apart. I'll read through the instructions later.
Thanks for the info.
TB
You will find that connector housing on page D6 (24 or 94/451) of the wiring harness repair manual I cited above. (The full part number is 90980-11162). You will find what repair wires go to it on page E-37 (293 or 363/451).
The connector housing is only $11 MSRP but it appears you can get the housing with the wires already in it many places (Amazon, Ebay, etc) Just do a Google search using that part number. That is the route I would go rather than trying to remove the existing pins and install new repair wires.
The secondary lock will be a bar that you lift. It should be on the opposite side of the finger tab to release the connector.
