Old 01-29-2023, 09:44 PM #1
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
Rotor Wear
Out of curiosity, does anyone know how much the brake pad shaves off the 4Runner rotor over the life of the pad, .05mm, 1mm or more? Maybe another way to put it, how many set of brake pads can one rotor go though before it needs to be replaced 2, 3 or 4 sets? For clarification I’m talking about the OEM brake pads and rotors. I know there are a lot of variables to this question but if anyone has any personal experience or has technical data I would appreciate it.
The reason I’m asking is that my current rear rotor are just a tad over 18mm. I know Toyota recommended replacing them at 16mm. My guess is at 18mm it should be good for one more set of brake pads even with resurfacing.
Thanks
Lexington is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 10:26 PM #2
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
As far as I can tell the rear rotors come new with ~18mm….
If someone can confirm the new thickness then you can calculate how much you wore through on first set of pads.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 11:32 PM #3
Lexington's Avatar
Lexington's Avatar
Yes that info would be helpful. If they come new at 18mm, then that mean these pads barely made a dent.
Old 01-30-2023, 12:33 AM #4
Lexington's Avatar
Lexington's Avatar
Did some further digging. According to this guy new OEM rear rotors are a little more than 18mm.
5th Gen Rear Rotors:
Nominal Thickness: 18.034mm (0.71")
Minimum Thickness: 16.002mm (0.63")
Outside Diameter: 312.166mm (12.29")
So it seems that my rear rotors are relatively new. Mine measured just a 18mm.
5th Gen 4Runner Brakes Upgrade (for 4th Gen 4Runner)
18mm , brake , pads , rotor , set
please wear seatbelts 3bears 3rd gen T4Rs 19 10-09-2019 10:58 PM
Tire wear Bourbonator Engines / Suspension / Wheels / Tires / Audio / Accessories 8 07-26-2016 12:09 PM
Brake Wear claydoctor 4th Gen T4Rs 4 04-30-2014 11:15 PM
Uneven rotor wear delucat2 4th Gen T4Rs 5 04-16-2013 06:36 PM
How much add'l wear from lift Falls 4th Gen T4Rs 0 07-01-2007 09:14 PM
