Old 01-30-2023, 02:05 PM #16
Finslayer83 Finslayer83 is offline
Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough
Have them on the rear and fronts are going in today.
got recommended by several Toyota/Lex techs as best bang for the money.
Finslayer83 is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 09:34 PM #17
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Originally Posted by Soneill View Post
The best combo I have found is Centric rotors with Akebono pads.
Ditto on that.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 01:46 PM #18
taildragger taildragger is offline
taildragger is on a distinguished road
Originally Posted by Dynamo View Post
Ditto on that.
Same.
Installed this combo last year and have been very happy with them. Slightly better bite, no dust, no strange wear, no noise
taildragger is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 07:47 PM #19
BimmerChop BimmerChop is offline
BimmerChop is on a distinguished road
Big fan of Akebono pads... I've ran them on multiple vehicles in the past and usually always my go to.
BimmerChop is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 09:30 PM #20
jax4pres jax4pres is offline
jax4pres is on a distinguished road
I like them as well, dust is NIL and bite and feel improved over OEM. Put them on front , reused oem rotors, no complaints whatsoever.
+1 would use em again no prolema
jax4pres is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 02:33 PM #21
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
Out of curiosity, when you say OEM are you referring to the factory OEM or the lower cost OEM brake pads?
Lexington is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 07:51 PM #22
4RL75 4RL75 is offline
4RL75 is on a distinguished road
Originally Posted by Lexington View Post
I’ve heard many good things about the Akebono break pads. Even the Car Care Nut guy gives them a thumbs up. Has you used these on your 4Runner? What are your thoughts?
For clarification I’m not looking for high performance brakes pads. I’m curious if the Akebono provides better breaking but still has a similar performance as the factory OEM brake pads.
One thing I can say about the OEM pads is current rear pads are down to about 15% and the rotors still feel smooth.
Thanks
Akebono also has performance street brake pads or AST, they offer a little more bite than the ProAct
4RL75 is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 08:44 PM #23
Lexington's Avatar
Lexington's Avatar
Thank you. Yes I’m aware of this. With performance pads you have much better stopping power, however with the trade off is usually a shorter life span and more brake dust.
Old 02-03-2023, 09:24 PM #24
I don't think this is the case, I had them on a explorer years ago and performed very low dust. Didn't keep the vehicle to confirm the life span.
All I know is they are better in every way than the ProAct, also more expensive, not by much thou.
Edit: I just rembered 1 drawback, pedal feel. With the ProAct the pedal felt very firm, with the performance pads you would lose some of that firmness, so you would have a bit of soft brake pedal but more initial bite.
Old 02-03-2023, 10:26 PM #25
Lexington's Avatar
Lexington's Avatar
Thanks! This was helpful.
Old 03-16-2023, 01:47 PM #26
mfast10 mfast10 is offline
mfast10 is on a distinguished road
I installed Akebono ceramic pads on the front and back of my at the time wife's 4runner. They don't seem to have a lot of dust and they stop better than the Raybestos pads I put on my Xterra.
mfast10 is offline   Reply With QuoteReply With Quote
Old 02-17-2024, 08:41 PM #27
gordonp gordonp is offline
gordonp is on a distinguished road
I can offer this:
I bought Akebono pads through RockAuto. They sell TWO DIFFERENT Akebono products, so be careful!!
The ProACT ceramic are categorized for "Daily Driver". I did not buy these.
The ASP Performance ceramic are categorized as "High Performance. I bought these.
My (2021 Canadian TRD Off Road) 4Runner came with OEM Advics pads directly from Tahara, Japan, with Friction Code FG.
Th ASP Performance (ASP606A rear, ASP976 front) were labelled with Friction Code GG.
My early driving does give me the expected (and desired) better Cold Bite (250-degree and lower). Less of the stock spongy feeling too, which wasn't expected. And since the Hot 'G' is the same, I expect all 650-degree and hotter braking to be the same.
So, in the first few minutes, I'm a happy camper. The Akebono ASP performance ceramic pads are giving me exactly what I wanted.
(Other data for later Googlers:
- my rear brake pads wore faster than the front pads
- in 50,000km I had only 2mm remaining on rear pads ... clearly time to change!)
- I drove these 50,000km in 3 years, much of it city-driving)
gordonp is offline   Reply With QuoteReply With Quote
Old 04-01-2024, 03:14 PM #28
Rocko9999 Rocko9999 is offline
Rocko9999 is on a distinguished road
Originally Posted by gordonp View Post
I can offer this:
Still happy with the pads? Any issue with the hardware not fitting correctly?
Rocko9999 is offline   Reply With QuoteReply With Quote
Old 04-01-2024, 07:04 PM #29
djeepin djeepin is offline
djeepin is on a distinguished road
Are you all saying that some pads had bad stopping power? meaning that I will not be able to stop as intended with such pads and got into collision? Right?
djeepin is offline   Reply With QuoteReply With Quote
Old 04-11-2024, 10:19 PM #30
Doodle210 Doodle210 is offline
Doodle210 is on a distinguished road
I just went with Raybestos Element3, and they're amazing. The stopping power is noticeable from OEM pads. My rotors were still in good shape so I'm holding off on replacing them, but I have my eyes on the Raybestos R-300 front and rear.
2016 4Runner Trail Edition Magnetic Gray
Mods done -
Under-hood LED light strip
In-Grill Hidden LED Bar
S&B CAI
Doodle210 is offline   Reply With QuoteReply With Quote
4runner , akebono , break , pads , thumbs
Oem pads vs Akebono RoadWarrior General Discussions 7 10-15-2021 12:05 PM
*** AKEBONO PROACT ULTRA CERAMIC BRAKE PAD SET (ACT606 & ACT976) Los Angeles, CA *** citizenpark For Sale: T4R Items 0 10-30-2020 06:50 PM
FS - 3rd Gen OEM Akebono ACT611 ProACT Ultra-Premium Ceramic Brake Pad Set OffRoadGuy For Sale: T4R Items 1 09-18-2013 12:34 PM
Anyone run Akebono pads?? techmen17 Maintenance/Detailing 4 05-16-2011 06:54 PM
