Old 01-28-2023, 09:08 PM #1
Land Cruiser Land Cruiser is offline
Land Cruiser is on a distinguished road
Help with front end Popping noise
2017 with 61K miles has developed a front in popping noise that I can't seem to locate.
Sounds like it is coming from driver's side. Only thing I could find loose was the driver's C/V axle at the diff. I replaced front sway bar bushings and had local 4x4 shop install the ECGS clam shell bushing.They torqued all the front suspension bolts and said bushings, etc appeared to be ok.
When I picked it up it seemed to have been an improvement, but the popping noise is back.
Threw and old gen1 Gopro on this morning and snapped a video before it started raining, so excuse the bad video.
Popping noise is only while moving at slow speeds and turning, don't notice while turning wheel back and forth stationary in driveway.
Need to locate and fix before buying new tires and lift.
4runpop.mp4 - Google Drive
Land Cruiser is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 10:56 PM #2
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Disregard the shop claims and make sure those rear Lower Control Arm bolts are torgued properly. IIRC they need to be torqued to 131 ft lbs. The telltales is the sound occuring as you shift from forward to reverse and back again.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 05:02 PM #3
Update:
Had to drop my Talons skid/cat shield to get torque wrench on rear LCA nuts. Service manual stated 129 ft lbs for the bolt and nuts. All seemed to be torqued as I didn't notice any movement prior to reaching torque specs.
However, initial test drive did not have the popping noise, so hopefully that was my issue and it doesn't return.
Old 01-29-2023, 08:14 PM #4
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
All my noises went away with bushing replacements on sway bar.
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 10:18 PM #5
vilkus vilkus is offline
vilkus is on a distinguished road
Front drive shaft slip joint greased?
vilkus is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 09:09 AM #6
ldchien ldchien is offline
ldchien is on a distinguished road
My pop was from the UCA bolts. Mine always seem to loosen up every month or couple months
ldchien is offline   Reply With QuoteReply With Quote
bushings , front , noise , popping , video
Front End Popping Noise When Turning Left? Gecko 5th gen T4Rs 30 02-17-2024 06:12 PM
Popping noise coming from driver front ghostmoney 3rd gen T4Rs 4 09-27-2016 03:28 PM
14' 4Runner popping noise from front end. Need help and idea. Apex Overland 5th gen T4Rs 7 04-18-2015 05:18 PM
03 Sport Front Popping Clunking Creaking Noise? dalandshark 4th Gen T4Rs 8 03-24-2015 07:47 AM
Popping noise in front left? Laubage 5th gen T4Rs 18 12-24-2012 06:40 PM
