2017 with 61K miles has developed a front in popping noise that I can't seem to locate.
Sounds like it is coming from driver's side. Only thing I could find loose was the driver's C/V axle at the diff. I replaced front sway bar bushings and had local 4x4 shop install the ECGS clam shell bushing.They torqued all the front suspension bolts and said bushings, etc appeared to be ok.
When I picked it up it seemed to have been an improvement, but the popping noise is back.
Threw and old gen1 Gopro on this morning and snapped a video before it started raining, so excuse the bad video.
Popping noise is only while moving at slow speeds and turning, don't notice while turning wheel back and forth stationary in driveway.
Need to locate and fix before buying new tires and lift.
4runpop.mp4 - Google Drive
