Old 08-17-2023, 01:44 AM #16
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by Jakeepoo3 View Post
He simply mounted it to the radiator support. I have a new radiator support laying around for my 2010 SR5 if you need measurements I can get to it real quick. I believe all the 5th Gen radiator supports are the same for the most part dimension wise. What's wrong with the OEM cooler? Never had issues with it and I go hard year round.
long, climbing grades found on the west coast and southwest combined with big ass tires, heavy armor and improper gearing, you end up with 200+ tranny temps. Sure, you can manual shift and keep the vehicle out of overdrive, but then you are driving like 40 mph on a freeway w/ a long steep grade with semi trucks trying to murder you in the slow lane....
Otherwise, if you're commute is relatively flat, then you will not run into this problem. Its a regional problem mainly is the best way to put it..
Old 08-17-2023, 11:13 AM #17
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Right, that makes sense improperly geared or something loading it down. I live in the beautiful Ozarks national forest of Arkansas. Definitely not flat. The bracket could be easily made for a couple dollars of plate. Easy way to make a killing building this stuff.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 08-17-2023, 11:24 AM #18
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Yep.
Steep climbs on paved roads, particularly at high altitude with lower air density is where I see the temps really rise.
02SE is offline   Reply With QuoteReply With Quote
Old 08-17-2023, 02:59 PM #19
Whippersnapper02's Avatar
He has them up: 2010+ 4runner Transmission Cooler Bracket Kit
– Iconic Fabrication
Old 08-17-2023, 04:38 PM #20
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Originally Posted by Whippersnapper02 View Post
According to my rad support you'll only have to drill and thread the top drivers side bolt.
Old 08-17-2023, 05:37 PM #21
I'd probably use a nutsert. I already have some and the installer as part of my arsenal.
Old 09-09-2023, 01:12 PM #22
teotwaki's Avatar
teotwaki teotwaki is offline
teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice
teotwaki's Avatar
I frequently tow my overloaded trailer all sorts of places that can really warm the trans up :-)
Jim _ My Adventure Blog:http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
teotwaki is offline   Reply With QuoteReply With Quote
Old 09-09-2023, 03:39 PM #23
teotwaki's Avatar
teotwaki's Avatar
Not so good news from Iconic
“Unfortunately not very good for the near term. After finally getting my hands on a 5th gen I see there is a lot of stuff in the way. I have a prototype bracket sitting on my bench waiting test fit but I'm not optimistic about it fitting correctly. I'll keep tinkering on it.
-Devon”
Old 09-09-2023, 08:38 PM #24
BADCUDA1 BADCUDA1 is offline
BADCUDA1 is on a distinguished road
I'd be interested in the 5th gen version. Be glad to help if needed.
BADCUDA1 is offline   Reply With QuoteReply With Quote
Old 09-09-2023, 08:40 PM #25
teotwaki's Avatar
teotwaki's Avatar
If you are in Kansas please contact Devon at Iconic
Link in the first post
Old 09-09-2023, 08:44 PM #26
Ohio
Old 09-10-2023, 12:58 AM #27
srsrogerissrs's Avatar
srsrogerissrs srsrogerissrs is offline
srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice
[IMG][/IMG]
Mine is on the same side but offset a bit from sitting flat against the radiator. Two generic L brackets with one off the rad support and one off the front grill support. Just drilled some holes and some nutserts.
2016 White TEP
srsrogerissrs is offline   Reply With QuoteReply With Quote
Old 09-10-2023, 01:15 PM #28
I mounted the cooler here on my 08 I haven't studied my 23 much but if I had a premade bracket I'd relocate the horns to the other side and basically mount it where the horns are. I like an air gap between the cooler and condenser.
Trans Cooler Mount: Need Kansas 5th Gens for New Product Fitment-hayden-698-trans-cooler-install-08runner-01-jpg
Old 09-10-2023, 03:30 PM #29
mrblah's Avatar
mrblah's Avatar
To make any mount work on passenger side,
you just have to bend things carefully out of the way.
I have a winch mounted high and I was still able to fit a tranny cooler.
Old 09-11-2023, 12:24 PM #30
The link now goes to a 3rd gen mount.
5th , cooler , devon , kit , volunteer
New trans cooler and radiator - should I get rad for manual trans? dogbreath650 3rd gen T4Rs 3 06-06-2017 02:14 PM
Re-Routing Trans Cooler Lines In Line With Rad Cooler Questions nc-grayson 3rd gen T4Rs 3 12-07-2016 09:09 PM
TOYOTA OEM TRANSMISSION COOLER Trans Cooler nissanh For Sale: T4R Items 1 03-30-2013 10:24 PM
Kansas 5th Gens? shawn719 5th gen T4Rs 2 05-15-2012 07:31 PM
Is that a trans cooler or oil cooler in front of the AC Condensor? kn38ms 4th Gen T4Rs 8 06-05-2008 07:41 PM
