Old 02-07-2023, 10:42 AM #1
bassman29 bassman29 is offline
bassman29 is an unknown quantity at this point
4wd noise
Hello
I have 2017 4runner 85K , long story short; the dealer changed out my transfer case fluid during the summer. I noticed a small leak in the fall coming from the aluminum crush washer. The dealer fixed the issue; I normally don't drive a lot in 4x4 except on the beach at low speeds and when it is snowing badly. The other day I was driving in 4wd and the noise was much louder than 2wd. Not sure if this is normal at higher speeds, around 30-40 mph. It does sound more like a loud humming noise. I usually don't drive this fast in 4wd, so I am unsure if this is just normal noise.
Thx
Bassman
bassman29 is offline   Reply With QuoteReply With Quote
Old 02-07-2023, 12:11 PM #2
mc813's Avatar
mc813 mc813 is offline
mc813 is on a distinguished road
mc813's Avatar
Can't say I've ever noticed a difference in sound when using 4hi vs 2wd. Did the dealer check the fluid and replace any that might've leaked out?
2019 TRD OR | Front Runner rack | Shrockworks sliders
Gone
2015 Trail
2000 SR5
mc813 is offline   Reply With QuoteReply With Quote
Old 02-07-2023, 12:15 PM #3
The bottom drain plug was leaking, so I assume they had to take the bolt out, replace the washer and drain, and fill the transfer case.
Thx
Old 02-08-2023, 10:29 AM #4
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Or they just torqued the drain plug a little more and called it a day…. Remove the fill plug and check if it’s full.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 07:06 PM #5
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
When switching from 2H to 4H I donít hear any difference but when Iím in 4L the gears do make a slightly louder and windy gear noise.
Lexington is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 08:57 PM #6
Good point, Lexington. OP, is the sound difference in 4H or 4L? Itís normal for 4L to be audibly different. You are changing from 1:1 to 2.28:1 gear ratio in the transfer case. So, the gear speed is 2.28x faster at the same road speed assuming the same transmission gear.
I would still confirm the transfer case is full after your leak and dealer visit.
Old 02-08-2023, 09:42 PM #7
Lexington's Avatar
Lexington's Avatar
Right thatís what I always assumed the noise was coming from. Switching between 2H & 4H youíre not really changing gear speed but when you go to 4L, well now your gears are spinning at a much faster rate for the same speed which produces that slightly louder, higher windy pitch noise.
Old 02-09-2023, 11:27 AM #8
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
The OP stated that he was hearing the noise at 30-40 miles per hour. Unlikely he was in 4Lo. If he was, then the noise was his engine screaming at high RPM.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 03:05 PM #9
Lexington's Avatar
Lexington's Avatar
Yes very true.
Bassman, for clarification when you were in 4WD were you in 4H or 4L?
Old 02-16-2023, 08:37 PM #10
Yes very true.
Hello
Sorry for the delay for some reason I am not getting notified, I was in 4H, I also was doing this when it was raining conditions just to ensure everything was working. Not sure if was just binding I normally drive with 4h at low speeds on the beach or when we get a lot of snow. But this year no real snow to drive in 4h.
thx
Old 02-17-2023, 01:51 AM #11
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
Does your paperwork say what fluid they used? OMM specifies SAE 75W
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
4wd , drive , noise , normal , speeds
Clicking noise around from passenger seat and loud knocking noise when accelerating Kool-Aid Problems & Warranty Issues 3 06-17-2019 09:18 PM
Drive shaft noise or U joint noise (LEXUS 4/06 TSB page 18) aka Driveshaft thump/bump rorad Problems & Warranty Issues 764 08-16-2016 08:49 AM
Clunking noise from rear end, trac bar makes noise when tapped with mallet thegipper 3rd gen T4Rs 2 04-18-2016 09:54 PM
03 4runner ticking noise (lifter noise) jgball Problems & Warranty Issues 1 12-18-2003 12:49 PM
