Originally Posted by Nikko
I installed the Lamin X on the fogs and want to remove it, but can't get to the edges to start peeling it off. Does the black plastic around it just pull off? Attached with clips? I have a 2021 TRDP if that matters. Thanks
I don't think you need to remove the trim. From inside the wheel well (remove the wheel well liner), you can access the fog lights which are easily removed.
