5amKot
Were you able to put the fuse panel cover back on with the add-a-circuit in place? It doesn't look like there's much of a gap between the cover and the tops of the fuses on my 2020 4Runner.
Originally Posted by Mandm723
Would there be any way to wire that mute button next to the steering wheel to a blank switch?
I like the way you're thinking. You know, the SmartCord is in essence an ordinary phone cord (it has an RJ11 connector on the end). I
believe the red and green leads are the ones used to power the detector (I
believe red is ground and green is hot), so probably yellow or black is the mute (and the other for the alert LED).
Research/test/verify all that before you go frying your 4Runner or equipment because I may not have my facts right, but I think the blank button idea would work. Anybody know for a fact?
