Old 02-09-2023, 01:34 AM #1
GLAD1ATØR's Avatar
GLAD1ATØR GLAD1ATØR is offline
GLAD1ATØR is on a distinguished road
GLAD1ATØR's Avatar
Stock roof rail reinstall question & advice.
Hi all.
If I am removing an aftermarket rack and replacing it with my stock roof rails. are thete any preventive measures I need to take for water? Or will they seal perfectly like factory when tightened down?
I know the bolts aren’t exposed and covered by the plastic end caps but should I be concerned at all for water in the recessed runoff seeping into the factory holes?
I know silicone is not technically recommended but should I used a gasket or rtv where the roof rails feet make contact with the roof sheet metal?
Thank you.
Stock roof rail reinstall question & advice.-ac6cef77-d6c9-4e91-a581-b86d18836e77-jpg
GLAD1ATØR is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 03:23 AM #2
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
Originally Posted by GLAD1ATØR View Post
Hi all.
Thank you.
I'm trying my best to remember the removal of my factory rack and from what I can recall, the rubber gasket that goes under the rail was installed without any additional silicone. I'm 99% sure that the only substance outside of the plastic caps and rubber gaskets was a little thread locker on the factory bolts.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 03:50 AM #3
fkheath fkheath is online now
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Hi all.
Thank you.
The sealing "washers" are very thin, paper thin. Thus you need something more substantial to replace them with. I used a long life silicone, but if you are afraid of silicone, then a very long life latex caulk. You really must use something instead of those thin washers.
fkheath is online now   Reply With QuoteReply With Quote
Old 02-09-2023, 09:13 AM #4
IslandJim's Avatar
IslandJim IslandJim is offline
IslandJim will become famous soon enough
IslandJim's Avatar
You could get new rubber washers if your concerned about their integrity.
Believe a butyl type of sealant if any is recommended.
2019 ORP KDSS MagGrey RSG Sliders/ICS Fab above console mount
IslandJim is offline   Reply With QuoteReply With Quote
Old 02-10-2023, 02:51 AM #5
The new washers would be just a thin as the original. Thus you should use your caulk/sealant of your choice.
Old 02-11-2023, 02:14 PM #6
LeekT4R's Avatar
LeekT4R LeekT4R is offline
LeekT4R will become famous soon enough
LeekT4R's Avatar
Put some RTV on it and be done.
LeekT4R is offline   Reply With QuoteReply With Quote
Old 02-12-2023, 01:42 PM #7
Tooly Tooly is offline
Tooly is on a distinguished road
You can buy a kit that has all the new parts needed in it from Toyota. I did that when I installed an earlier trail edition rack on my 2021.
2021 4Runner ORP - Canada Spec
1989 Land Cruiser BJ74 - Sold
1986 Land Cruiser BJ70 - Rusted Away
Tooly is offline   Reply With QuoteReply With Quote
Old 02-16-2023, 09:33 PM #8
CentcomPete CentcomPete is offline
CentcomPete is on a distinguished road
Careful with the bolts!
Be careful not to loosen one bolt too much more than the other when removing them. SERIOUSLY - if you do, the "clip" underneath that the bolts screw down in to will separate and fall into the abyss.
Unscrew them each at an equal amount until they come out as opposed to removing one completely before the other.
2023 TRD ORP 4WD Lunar Rock
2013 SR5 4WD Mag Grey (Totaled in 2022)
CentcomPete is offline   Reply With QuoteReply With Quote
factory , rails , roof , stock , water
Quick Roof Rail Question DAWG NATION 3rd gen T4Rs 13 10-27-2019 10:37 PM
WTB - stock roof rail craaaazzy For Sale: T4R Items 1 05-23-2017 12:30 PM
Roof Rack feet/stock rail securing mc813 5th gen T4Rs 16 07-04-2015 08:04 PM
