Old 02-13-2023, 01:31 AM #1
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Need electrical help please!
Hi all! So I was using a continuity tester/multi meter (the one with 2 probe leads) to figure out which wire provides power to the rearview mirror dimmer sensor there are only 2 wires on the connector. I accidentally touched the probes together and heard a tiny pop/spark. After investing I found out my dash cam stopped working. It was powered by the rearview mirror with a Dongar tech adapter. Also, the rearview mirror dimmer, the seat heaters, sunroof, power windows, power inverter button, windshield de-icer, (clock jumped ahead 1 hour), front aftermarket camera, backup camera, heat/cool and A/C knobs and lighting all stopped working. Also the map and dome lights turn on when I start the engine? I checked some of the fuses for items mentioned above and they seemed to be fine. Is there anything else I should look for? Did I fry something very important? Everything else seems to work and I even drove it around the block to see if there I was anything else wrong I could notice but nothing else at the moment. Any help/advice would be greatly appreciated. Thanks!
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 01:57 PM #2
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 04:49 PM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Disconnect the battery. Then check all fuses in both fuse blocks (with a meter on the ohms scale) to see if any are blown and replace any that are. Then reconnect the battery and see if everything is working. If not, then you have to start troubleshooting, or take it to a repair shop. Toyotas are very unforgiving when it comes to electrical issues.
Old 02-13-2023, 05:31 PM #4
Marvin_Rall's Avatar
Marvin_Rall Marvin_Rall is offline
Real Name: Marvin S. Rall
Marvin_Rall is on a distinguished road
It sounds like you may have shorted out a fuse or a control module while using the continuity tester. When you touched the probes together and heard a spark, it may have caused a surge of electricity that damaged the electrical components in the system.
Based on the symptoms you described, it appears that multiple electrical components are not working. You should check the fuses for each of the systems that are not functioning properly. If the fuses are fine, then the problem could be with a control module or relay that controls those systems.
In conclusion, I would recommend having your vehicle inspected by a professional to determine the cause of the problem and make the necessary repairs.
Marvin_Rall is offline   Reply With QuoteReply With Quote
Old 02-16-2023, 10:56 AM #5
Humble Leader's Avatar
Humble Leader Humble Leader is online now
I would bust out the test light and test fuse by fuse. engine bay and under dash, you can do them all in maybe 10 minutes
Humble Leader is online now   Reply With QuoteReply With Quote
Old 02-16-2023, 11:31 AM #6
Problem solved! It was the 10A ECU-IG No. 2 fuse. Apparently all the things I listed above is on that fuse. Had no idea!
Old 02-17-2023, 05:32 PM #7
did they change the fuse panel from 2012 to 2015? my ECU-1G No. 2 doesn't have that many things on it. my sunroof, power seats, etc are all on different fuses. My IG No. 2 only lists these
Air conditioning system, multiport fuel injection system/ sequential multiport fuel injection system
Old 02-17-2023, 08:29 PM #8
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Unhappy
Hi emmantik,
I just went over the wiring diagram for the 5'th Gen 4Runner..., (NO WORRIES)! Eighter you took out a: 25A Sunroof fuse, your S/HTR fuses, a 7.5A A/C fuse, a RAD NO-1 (radio) fuse, along with a: 30A AMP radio fuse... all at the same time... or you tripped your ECU-IG NO-1 10A or ECU-IG NO-2 10A (D/S FUSE-BOX), or the 10A ECU-B fuse under the hood (Engine-room; just below the SHORT-PIN!
I would check those ECU fuses bc these will affect quite a few circuits at the same time... but more likely than tripping 5 separate fuses at the very same time... make sense(?)! Please let us know what-cha find out!
~rig~ Best to you!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 02-17-2023, 08:34 PM #9
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Hi @emmantik ,
So sorry; I didn't see this post today... LOL
Cheers ~rig~
dimmer , mirror , power , rearview , working
Need some electrical help Shabang 5th gen T4Rs 4 07-04-2020 04:34 PM
Electrical help Reef Inmate 3rd gen T4Rs 10 10-28-2014 10:09 AM
Electrical short?? Random electrical issues? Fanman47 4th Gen T4Rs 5 06-09-2014 03:12 PM
Electrical help Bbryan1220 3rd gen T4Rs 6 02-24-2013 05:31 PM
Electrical help jrkentucky 3rd gen T4Rs 1 02-28-2006 08:30 AM
