Originally Posted by emmantik
Hi all! So I was using a continuity tester/multi meter (the one with 2 probe leads) to figure out which wire provides power to the rearview mirror dimmer sensor there are only 2 wires on the connector. I accidentally touched the probes together and heard a tiny pop/spark. After investing I found out my dash cam stopped working. It was powered by the rearview mirror with a Dongar tech adapter. Also, the rearview mirror dimmer, the seat heaters, sunroof, power windows, power inverter button, windshield de-icer, (clock jumped ahead 1 hour), front aftermarket camera, backup camera, heat/cool and A/C knobs and lighting all stopped working. Also the map and dome lights turn on when I start the engine? I checked some of the fuses for items mentioned above and they seemed to be fine. Is there anything else I should look for? Did I fry something very important? Everything else seems to work and I even drove it around the block to see if there I was anything else wrong I could notice but nothing else at the moment. Any help/advice would be greatly appreciated. Thanks!
Hi emmantik,
I just went over the wiring diagram for the 5'th Gen 4Runner...,
(NO WORRIES)! Eighter you took out a:
25A Sunroof fuse, your
S/HTR fuses, a
7.5A A/C fuse, a
RAD NO-1 (radio) fuse, along with a:
30A AMP radio fuse... all at the same time... or you tripped your
ECU-IG NO-1 10A or
ECU-IG NO-2 10A (D/S FUSE-BOX), or the
10A ECU-B fuse under the hood (Engine-room; just below the
SHORT-PIN!
I would check those ECU fuses bc these will affect quite a few circuits at the same time... but more likely than tripping 5 separate fuses at the very same time... make sense(?)! Please let us know what-cha find out!
~rig~ Best to you!
