Old 02-13-2023, 12:16 PM #1
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
2011 Rear Speakers NOT WORKING *SOLVED*
My apologies if this thread seems redundant but I thought it worthy to start this thread in case some are still struggling with No Sound from the rear or hatch speakers in their 5th gen Toyota 4Runner.
Replace those cheap Toyota stock speakers (if you can call them that)
*you can test them with a 9v battery*
Because they are wired in series if one blows on either side (that side will not work) MY REAR DOOR SPEAKERS AND HATCH SPEAKERS were ALL blown out by the previous owner.
If your rear door speakers work just jumper the hatch speakers at the connector on the speaker wiring harness to bypass the hatch.
I replaced the rear door speakers with Kicker 47KSC6504
KS Series 6-1/2" 2-way car speakers from Crutchfield.
Kicker 47KSC6504 KS Series 6-1/2" 2-way car speakers at Crutchfield
(Crutchfield says they won't work but they mounted up perfectly with the enclosed Kicker speaker adapters and Metra 72-8104 Speaker Wiring Harnesses)
Metra 72-8104 Speaker Wiring Harnesses For select 1992-up Toyota-built vehicles — adapt new speakers to the factory wiring plugs at Crutchfield
For the hatch speakers I went with:
Kenwood KFC-1396PS
Performance Series 5-1/4" 2-way car speakers
Kenwood KFC-1396PS Performance Series 5-1/4" 2-way car speakers at Crutchfield
Now: All 8-speakers work together.
Party Mode disables the Rear Door speakers and sends more power to the rear hatch speakers.
*Note: You'll want to sound deaden the hatch panel or any decent speakers will vibrate and rattle.
I am running a BV800ACP head unit w. a built-in internal amp (20 watts RMS/80 peak x 4 channels. This powers 6-8 speakers in this setup nicely.
Attached is a picture showing how to bypass the hatch speakers if you only want the rear doors working out of series.
2011 Rear Speakers NOT WORKING *SOLVED*-thumbnail_img_3366-jpg
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 05-01-2023, 01:49 AM #2
damon323 damon323 is offline
damon323 is on a distinguished road
Great write up! Thank you for confirming that the 6.5 Kickers will fit the rear doors. I just bought two sets of 5.25 speakers for the rear doors and the hatch. Haven’t installed the hatch, I’m returning to Crutchfield. Now that I know the kickers will fit, I’m probably returning those for the kickers. I want 6.5 speakers, the 5.25’s are just too puny in my opinion. Wish the Kickers could fit the hatch. Trail Grid Pro sells a full speaker replacement kit that’s all Kicker. They partnered with them. The rear doors and the hatch are the exact ones they use that you referenced. They must have some custom adapter. You can only buy their full kit for like $588
damon323 is offline   Reply With QuoteReply With Quote
door , hatch , rear , series , speakers
Rear Speakers not working trdproven 5th gen T4Rs 55 10-11-2023 05:15 PM
Rear door speakers not working! doublecrunch 5th gen T4Rs 0 04-02-2020 08:45 PM
rear door speakers not working Bootleg 5th gen T4Rs 5 12-12-2019 12:00 AM
rear speakers stop working after radio swap, please help Wildcat Engines / Suspension / Wheels / Tires / Audio / Accessories 3 06-17-2013 11:11 PM
Help! Rear speakers stopped working. rsmith0399 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-14-2009 01:49 PM
