Old 11-21-2024, 02:51 AM #46
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Originally Posted by Robb235 View Post
So do the 4wd Limiteds not have the ability to shift into 2wd? Just H4 (similar to AWD), H4L (true 4x4), and L4L (4Low)?
No H2 (2wd)?
That's correct.
02SE is offline   Reply With QuoteReply With Quote
Old 11-22-2024, 10:39 PM #47
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 will become famous soon enough
Robb235's Avatar
Real Name: Robert
Originally Posted by 02SE View Post
That's correct.
Bummer. Seems like the 5th gens got screwed on the transfer cases. I wonder if the VF4AM multi mode t-case from the 4th gen could be swapped in without much difficulty?
1999 Toyota 4Runner Limited 4x4 - Turbocharged GTX3071 - URD AFR Sensor Calibrator - DW255 fuel pump - 2JZ Supra 315cc “teal top” fuel injectors - Rear Elocker Retrofit w/ 4.30 gears - 2wd Low (2Lo) On Demand - 231mm Tundra Brake Upgrade - Hayden 699 Transmission Cooler - Monitoring ATF Temps w/ My iPhone - DIY Projector Headlight Retrofit - Backup Camera Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear)
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 11-25-2024, 01:39 PM #48
thatoneguy's Avatar
thatoneguy thatoneguy is offline
thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough thatoneguy is a jewel in the rough
thatoneguy's Avatar
Is that really "getting screwed"? For all the effort Toyota went through on the part-time 4WD models to have an Automatic Differential Disconnect when 4WD isn't in use.... the full-time 4WD Limiteds get the same EPA fuel economy numbers, so RWD vs AWD/4WD on the 5gh gen doesn't seem to carry much of a fuel economy penalty....
If I had a Limited, I definitely wouldn't be bummed that I can't put it in 2WD. The only reason I'd want to is if I had to put a non-matching-diameter spare tire on in an emergency; if I had 2WD, I'd put it on the front axle and stay out of 4WD, and if I had full-time 4WD, I just wouldn't do it.
2023 TRD Offroad Premium
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
thatoneguy is offline   Reply With QuoteReply With Quote
Old 11-25-2024, 03:16 PM #49
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
Yes, I really would say that is getting screwed. Going from the super capable multi mode t-case that the 3rd gens (VF3AM) and 4th gens (VF4AM) had, to what the 5th gens seem to have is a downgrade for sure. 4th gens seemed to have the best of it; 2wd (because not everyone wants to be in 4wd all the time, ever blasted around in 2wd w/ rear diff lock engaged?), 4wd w/ center diff unlocked for snowy icy conditions, 4wd w/ center diff locked aka true 4x4 (duh), and 4Lo with center diff either locked or unlocked. I know a lot of people won't care about 4Lo w/ center diff unlocked, except that it's pretty damn useful for when you're trying to reverse with a trailer pushing it up a steep driveway. I modified my 3rd gen to give me 2Lo and it's truly a game changer trying to negotiate the 90 degree turn reversing into my driveway and snaking my boat around the side of my house. Just makes it so much easier. Toyota should've at least given the ORP or whatever their supposedly highest capability trim level is the most capable t-case they could, but instead apparently elected to give it a downgrade from what 3rd and 4th gens had. So yeah, definitely got screwed for sure.
4wd , axel , full-time , power , system
Limited's Full-Time 4WD system like AWD? ThePirate 5th gen T4Rs 15 10-25-2020 11:29 PM
Can you tell from the VIN if a Limited model is part-time or full-time 4WD? speedmaster General Discussions 6 10-07-2020 09:55 PM
Limited's Full-Time 4WD Like AWD? ThePirate 5th gen T4Rs 14 03-03-2019 08:16 PM
Full-Time vs Part-Time 4WD Explained with Disassembled Transfer Cases green_manalishi Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-13-2018 02:22 PM
Center diff confusion (Full time 4WD Limited models) AudiTech 5th gen T4Rs 1 03-14-2015 01:35 AM
