Old 03-16-2023, 09:50 PM #16
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Looks good! Thanks for the updates!
nglayton is offline   Reply With QuoteReply With Quote
Old 03-17-2023, 05:58 PM #17
aesthetics aesthetics is offline
aesthetics is on a distinguished road
First off love the new cover plate and standoffs, very elegant solution I was going to do something similar with a piece of spare plexiglass myself. I'm mounting in the little area between the backseat and my drawers. One idea that would be awesome is to include some stickers for the outputs (will be using Blue Sea Systems 8214 stickers for now)
Here is my beta board to mock everything up to my drawers, will replacing the board to a matte one and adding a plate behind the Redarc BCDC charger.
I'm coming from an all in one battery box I built after many hours of research and then trial and error getting the connection right between the shunt and the redarc bcdc. I really wish this out when I built it 2 years ago.
This makes the connections plug and play, you really just need to buy the components and wire it up as instruction guide lists. The wiring guide is great letting you know exactly which cable goes to which slot and the recommended gauge (I highly recommend double checking a wiring gauge chart to what amp and length you should gauge your wires)
Notes
- Build quality is excellent the standoffs and components (even the midi fuses are high quality)
- Easy to read legends and labels on the PCB
- Installation was super simple just had to cut and strip some wires (painful to cutoff all my perfectly crimped lugs) but this a superior solution.
aesthetics is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 02:29 PM #18
AMLOR AMLOR is online now
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
This is really a great solution for DIYers. Simple, adaptable, more options than a Blue Sea Safety Hub...genius really. That said, am I going to rip out everything I have done electrically over the last few years...no. But if I have to do it over again this would be purchase #1! Nicely done!
This would also be of great interest to those converting vans to RV's as well...just sayin...
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is online now   Reply With QuoteReply With Quote
Old 04-02-2023, 07:56 PM #19
Chris send over the plastic cover piece and new plastic standoffs and replacement mounting screws. It looks like replacement screws are a lil bit longer, the original ones only had a few treads into the plate.
It also came with replacement philips screws to replace the midi fuse t15 torx heads but I couldn't get them off with precision driver set, will have to see about getting a bit to loosen em up. But I don't plan on replacing to philips.
Really enjoying the plastic standoffs and the cover, it was a little scary working having it exposed.
Old 04-03-2023, 04:12 PM #20
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Titanpat57's Avatar
Real Name: Patrick
I'm guessing this window has closed. I'm looking on adding 12 to 12 charger and redoing my wiring on my off road trailer this spring.
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
Old 04-03-2023, 04:31 PM #21
Skykomish's Avatar
Skykomish Skykomish is offline
Skykomish will become famous soon enough
Skykomish's Avatar
Yes, the giveaway closed a few weeks ago. The 10% off discount code is good through at least the end of the summer, put "t4r" in the notes field when filling in the order form and it'll be applied to all power distribution products on your order.
Skykomish is offline   Reply With QuoteReply With Quote
Old 04-15-2023, 06:46 PM #22
Skykomish's Avatar
Skykomish's Avatar
Short clip of a much longer test:
Post-testing teardown and inspection:
Old 04-23-2023, 12:14 PM #23
Skykomish's Avatar
Skykomish's Avatar
Pull test, this one failed at 85 ft-lbs. Most of my tests results were around 100 ft-lbs but this is the only one I recorded.
Rated current test of both an APDS and Egon DC Hub:
apds , auxiliary , battery , installation , product
Anybody ever use this brand/product? ghs215 4th Gen T4Rs 4 04-17-2020 08:24 AM
New RCI product for the GX! RCI Offroad Lexus GX470/460 0 10-30-2019 12:33 PM
New Product request spizike9 Rago Fabrication 3 07-22-2019 11:57 PM
Has anyone used this product? chetJ 5th gen T4Rs 23 03-16-2012 12:15 PM
TRD product's for 4R Falls 4th Gen T4Rs 4 04-06-2006 07:12 PM
