Originally Posted by McPixelz
Sway bar bushings could cause a steering vibration? I tried swapping the wheels and it did not seem to change.. My sway bar end links are definitely shot as they clunk over big bumps. I know my LCA bushings had a little itty bit of play with a pry bar too. These can make me feel a vibration? I thought it would be the moving parts..
Bad Lca bushings might. Normally they would make the steerling pull or push.Replacing the bushings will only help and also eliminate them as a cause for vibration.
