Old 04-17-2023, 03:59 PM #16
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Originally Posted by dipNrip View Post
Almost the same location as mine but looks way worse. Definitely have them do it under warranty.
I’ve driven 1k miles and lost a small fraction. Since it’s gotten warm out it hardly leaks at all and most likely only after it cools. I can see it bead up after cooling in to spots I listed previously.
Took it in this morning and they are fixing it under warranty. Seems like we just had some bad luck here. Don't see many complaints in regards to these having water pump issues.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 12-29-2023, 09:48 PM #17
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
My water pump just started leaking at 36k miles. It’s a 2018 also
NorthPark is offline   Reply With QuoteReply With Quote
Old 12-30-2023, 07:59 AM #18
dipNrip dipNrip is offline
dipNrip is on a distinguished road
Definitely seems to be an issue with the 2018s. There was no videos online until this year on how to replace the 5th gen water pump and they were all 2018s I saw. Most look similar to mine in that they are gasket leaks not pump failures. Maybe bad gasket?
On mine I finally gave up and took it took it to the dealership. I had the parts and coolant so it was only $450 and got done in just under 3 hours. It would have taken me forever with out a lift to get everything out and put back.
On mine you can see where the gasket failed on the engine side of the top half on the inlet water housing (water pump gasket not oring)
I only put in about a quart or so over 8 months so it wasn’t a bad leak.
dipNrip is offline   Reply With QuoteReply With Quote
Old 12-30-2023, 10:09 PM #19
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
You'd think with 17 bolts that leaks wouldn't be a problem!
coolant , didn’t , gasket , leak , pump
Slight water leak.. water pump or??? LargeOrangeFont 4th Gen T4Rs 6 08-26-2019 06:52 AM
3.4l metal water pump gasket 19963.4lsr5 3rd gen T4Rs 2 11-13-2018 04:56 PM
Leak from water inlet/water pump joint - V8 GLP 4th Gen T4Rs 5 01-12-2017 10:52 PM
Water pump or head gasket choff1212 3rd gen T4Rs 13 11-08-2016 01:50 PM
Water pump gasket?? Twams 3rd gen T4Rs 3 10-20-2008 05:55 PM
